Greg's Hemi Orange Adventure
Author Topic: Greg's Hemi Orange Adventure  (Read 34548 times)
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Greg's Hemi Orange Adventure
« Reply #60 on: May 19, 2008 - 09:05:53 AM »
Looking great, Greg!  :thumbsup:  Lotsa progress!  :grinyes:
Every time I hear someone mention cowl leak I cringe as I have to investigate mine some day...   :violin:
Offline NoMope Greg
« Reply #61 on: May 19, 2008 - 11:42:29 AM »
Phil, mine was pretty easy to seal.  Assuming you have the wide moulding at the base of the windsheild, take it off and check how badly it's corroded.  I sealed mine (a temporary repair, but should be effective) with black latex sealant I found at Home Depot.  Most of the rust spots are pretty small, but one was about the size of a quarter.  I was thinking about using the same thing on the taillight housings, but I think I'll spring the $30.00 for the paint kit.  :money: :roflsmiley:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #62 on: May 19, 2008 - 11:45:05 AM »
Thanks for the tip, Greg!  :thumbsup:
I was thinking I was just going to get a tube of clear silicone and just spakle all around the trim so water can't get under it.  :22yikes:
I know, Mickey Mouse is in my toolbox....  :bricks1:  :roflsmiley:  :smilielol:
Offline NoMope Greg
« Reply #63 on: June 01, 2008 - 12:57:02 AM »
Before today, I was always unhappy with the fact that the people who installed the manual trans in my car just hacked holes in the floor for the linkage and didn't do it "right."  After today, I'm a little more tolerant.  First thing was to test fit the new Sherman four-speed hump and of course, it didn't fit right, so I spent some time with hammers, vise (as a sheetmetal brake) and pliers to get it to fit better.  Once I got it close enough to be able to bond, I started cutting out some of the old sheetmetal.  I had intended to use the cut-off wheel on me angle grinder, but of course, the aftermarket wheel was too loose on the grinder, so I resorted to sheetmetal snips.  That was hard work.  Gonna look for the right cutoff wheel or, failing that, some nibblers.
Greg
Offline 422STROKER
  • Member Since 6/3/06
« Reply #64 on: June 01, 2008 - 07:13:01 AM »
Good Job Greg,
Keep at it.  If there isn't much below where you are going to cut I've used a cheap jigsaw in the past, even a sawzall on the angle will cut nice.
Tom :2thumbs:
Tom
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #65 on: June 01, 2008 - 07:47:16 AM »
Greg,
Great start on the hump  :2thumbs: Iwould look for a good cut-off tool (cheap, I have a walmart one) It woorks great for that stuff.
Whats the update on the 440?
Go Fast & Have Fun...
Offline hemiken
« Reply #66 on: June 01, 2008 - 08:52:08 AM »
 :iagree: a little more clean up and it will look factory buddy.......................... Just make sure the area around where the flange meets the floor, that the floor is cleaned up with a wire wheel on a grinder for better weld penetration.......................... otherwise keep up the good work :2thumbs:
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #67 on: June 01, 2008 - 07:07:19 PM »
It looks like we got the same floor hump with the extra bump on the outer lip.I just hammered it flat and welded it. It helped using about a dozen sheet metal screws to hold it flat on the floor too. Good luck!  :2thumbs:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline NoMope Greg
« Reply #68 on: June 01, 2008 - 09:00:23 PM »
Guys, thanks for the support.  Chuck, that's exactly what mine looked like - what the heck is that about? :dunno:  It also didn't fit right on the other side - that's why I used the vise as a sheet metal brake.  It's close enough now that it should hold with the aid some sheetmetal screws.  I'm going to use panel-bonding glue instead of welding (hey, I'm a beginner, don't have a welder and it's relatively easy).
No news on my engine - Summit is supposed to ship my pistons in about two weeks.  I still have to decide on all the other things I need and order them.
Took the day off today - went on a little family outing to see a steam locomotive pulling the Amtrak and a big Corvette show downtown.  I'll look for a nibbler this week.
« Last Edit: June 01, 2008 - 09:02:26 PM by Greg's HO R/T »
Greg
Offline CHUCKS71
« Reply #69 on: June 02, 2008 - 06:33:31 PM »
The extra bump might be for a 71-74 B Boby I know they use the same type of hump.If you are going to use panel-bonding glue I would put a few screws or rivits on each side to make sure it stays in place. Chuck
Offline NoMope Greg
« Reply #70 on: June 09, 2008 - 02:41:00 AM »
Spent several hours this weekend cleaning up the holes in the floor - straightening sheetmetal, grinding, deburring with a file, cutting off little "hang-nails" that would tear up my arms later if I have to remove the trans from underneath.  I also spent a bunch of time scraping the floorpans to get them cleaned up some.  I ache all over - and tomorrow will be worse.  :'(  I still haven't decided if I'm going to paint in there.  Maybe POR-15, but I can't say I'm too worried about rust.
Got another postcard from Summit saying my pistons have been delayed until 6/27.  :swear:  Depending on what kind of credit I can get from canceling the order (because they were part of a rebuild kit), I may be contacting 440Source for pistons.  EDIT: So much for canceling the order.  I'd lose over $200 in the deal canceling the Summit pistons and getting them from 440Source.  Sigh.  :walkaway:
« Last Edit: June 10, 2008 - 02:53:32 AM by Greg's HO R/T »
Greg
Offline hemiken
« Reply #71 on: June 09, 2008 - 03:39:48 AM »
Hey Greg,
That sucks about the Summit pistons not showing up and even more of a delay for delivery buddy.
I think their is a POR-15 paint that has the rust inhibitor built in to the paint, you will have to do a double check.  Cleaning is the worst part, but the more you do now is the less that will need doing later :2thumbs:
Glad you got rid of those little nasties from ripping your arm apart for future teardowns :grinyes: Good thinking, Looks a lot better. When does the hump go back in old mate. :clapping:
Offline 422STROKER
« Reply #72 on: June 09, 2008 - 06:57:49 AM »
Looking good, keep at it.
At least get some good oil paint on there.  I used a Rustoleum product for stuff that I didn't use the por-15 on.
Tom :2thumbs:
Tom
Offline wally426ci
    • maryland mopars
« Reply #73 on: June 09, 2008 - 08:18:14 AM »
POR-15 can paint over rust, thats what i did my floors and frame rails with....  :working: looking good!
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline KNOT0623
  • 1970 A66 Challenger
« Reply #74 on: June 12, 2008 - 05:05:10 PM »
Yo Greg...She is LOOKING GOOD!!!! :woohoo:
Get in, Sit Down, Shut up and HOLD ON!!!!
1970 A66 340 Challenger 4-speed
1970 T/A Challenger 4-speed
2006 Ram 2500 Diesel
2008 BMW M3 Vert
