Author Topic: 440 6 pac  (Read 1696 times)
Offline chall7074
440 6 pac
« on: April 05, 2008 - 12:13:50 PM »
does anyone know of a non r/t challenger having a 440 6 pac from factory
Offline Super Blue 72
    • Phil's Super Blue '72
Re: 440 6 pac
« Reply #1 on: April 05, 2008 - 09:16:04 PM »
You can see my  :2cents: in the other thread you made, but you never know with Mopar......  :dunno:
Re: 440 6 pac
« Reply #2 on: April 06, 2008 - 02:25:30 PM »
not unless the car was built as a non R/T & modified later by the factory for a display , other than that all 440+6 would have been coded as R/Ts as well
« Last Edit: April 07, 2008 - 02:28:03 AM by Chryco Psycho »
Offline Challenger6pak
Re: 440 6 pac
« Reply #3 on: April 06, 2008 - 07:47:22 PM »
not unless the car was built as a noin R/T & modified later by the factory ofr a display , other than that all 440+6 would have been coded as R/Ts as well
:iagree:The 440+6 had to be ordered with the R/T package.  Chrysler did this for warranty issues.  The R/T package had sway bars and other heavy duty pieces that Chrysler wanted to be with the 6 pack set up.  Disc brakes were also a mandatory option with the 440+6.
Re: 440 6 pac
« Reply #4 on: April 07, 2008 - 02:29:27 AM »
disc brakes should have been mandatory on all performance Mopars , that had them on the Imperial in 51 , why they were not std in the 60s I have no idea
Offline PlumCrazy
Re: 440 6 pac
« Reply #5 on: April 08, 2008 - 10:26:15 PM »
Not true.
Offline FJ5_440
  • Wisconsin
Re: 440 6 pac
« Reply #6 on: April 08, 2008 - 10:29:38 PM »
Drum brakes had a lower rolling resistance and were often preferable for a drag car.  My 440-6 car had 4 wheel drums.
** Shane **
Re: 440 6 pac
« Reply #7 on: April 09, 2008 - 09:37:21 AM »
You are correct.  I made a mistake.  I remembered something with the brakes being a manditory option.  Disc brakes stuck in the brain.  According to the order sheets, Heavy Duty drum brakes were part of the R/T package. If the optional performance axle package "Super Track Pac" (4:10 DANA) was ordered, then disc brakes were part of the package.  You could get this package with the 440+6 or the Hemi engines only.
