Junk in the Trunk (what spare parts do you keep with you on the road?)
Author Topic: Junk in the Trunk (what spare parts do you keep with you on the road?)  (Read 1387 times)
Offline FJ5_440
  • Wisconsin
I have been driving old cars long enough to know that it is a good idea to have a couple simple hand tools and a few spare parts along whenever you take the car for a drive.  Even with triple A and a cell phone, I think it is better to NOT have to tow my car in case something breaks.  I picked up a spare ballast resistor, and a starter relay as a precaution, but what kind of field repair items do you guys take with you?
** Shane **
Offline bordin34
Re: Junk in the Trunk (what spare parts do you keep with you on the road?)
« Reply #1 on: April 05, 2008 - 05:43:37 PM »
Ballast, plug wires, ecu, cap, rotor, rtv, 6 inches of fuel line, 1 quart of oil, power steering fluid, trans fluid, brake fluid, and a voltage regulator. But I have no jack if I get a flat.
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
Offline dutch
« Reply #2 on: April 05, 2008 - 06:06:33 PM »
rope & ducktape... :bananasmi
*** Bart ***
« Reply #3 on: April 05, 2008 - 06:07:37 PM »
A car cover :dunno:
Offline GoodysGotaCuda
« Reply #4 on: April 05, 2008 - 06:09:18 PM »
when i daily drove my car i usually had
spare lights (brake/turn)
voltage regulator
ignition ecu
ballast resistor
various radio shack jumper wires
multi-meter
wrench set
socket set
pair of old belts
quart of oil
quart of atf
thats all i recall off hand. in the tool box of my pickup, i have all sorts of stuff!
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline hemi71
« Reply #5 on: April 05, 2008 - 06:43:25 PM »
Set of misc tools, mechanics wire, fuel line, spare upper & lower radiator hoses, heater hose, 1 gallon of coolant, ballast resistor, ECU (if so equipped), V regulator, fuel pump, 1 qt of oil, points (if so equipped), rotor, dist, 1 long plug wire, #14 gage wire (10ft), fuel filter. When you've driven these old Mopars as long as i have, you are going to break down, no matter how well you maintain them. Id like to avoid leaving them on the side of the road, or getting them towed if I can. Most of the above stuff is from my past experience. Maybe I'm a bit paranoid, but better safe than sorry.
Kinda makes for a full trunk when it's an e-body and you add two chairs, a cooler, and some display stuff. Add a pop-up tent for carlisle and a B body trunk looks like a great alternative.
 :cheers:     :roflsmiley:
« Last Edit: April 05, 2008 - 06:44:56 PM by hemi71 »
« Reply #6 on: April 05, 2008 - 07:32:07 PM »
You can make new friends when you break down. I use Visa/master charge for a transporter.  I used to carry all that stuff, but now adays I stay within 50 miles of home. The car cover is for acid rain.
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #7 on: April 05, 2008 - 07:57:57 PM »
We might need to get some more internet space before MEK posts i this thread, LOL.  Some of you guys know what I am talking about  :smilielol:
Yellow_Fish
« Reply #8 on: April 05, 2008 - 08:08:13 PM »
A cooler
Offline LAA66
« Reply #9 on: April 05, 2008 - 10:16:15 PM »
 I mostly carry electrical components. Also spare belts, tools, air pump, and tire plugs. No spare or Jack though they take up too much room for the occasional cooler.
Offline 71bigblock
    • Steve's Mopars
« Reply #10 on: April 05, 2008 - 11:03:47 PM »
I dont drive mine far enough away to worry about anything.   :lol:
Mine is very well mannered, 70,000 original miles, doesnt burn a drop of oil.  Most of my miles are the 3 miles to town and back.   ;D
Offline ntstlgl1970
  • T a c o c a t
« Reply #11 on: April 06, 2008 - 02:24:15 AM »
when it was still a daily driver:
some assorted hand tools
spare distributor (complete)
module
some plug wires
jumper cables
quart of oil
quart of trans fluid
piece of vacuum line
piece of trans cooler hose - ever have a cooler line fail - it sucks!
gallon of water
$20 cash in smaller bills and a few bucks in quarters for phone calls all stashed away somewhere where I won't go spend them on junk
a fishing tackle box full of holley stuff (used to go to the track a lot)
timing light
white shoe polish
can of fix a flat
rain x
AAA card
I would drive anywhere in my car so that could mean the beach or the snow
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #12 on: April 06, 2008 - 06:08:36 AM »
multi-meter
wrench set
socket set
pair of new v-belts
3 quart of oil
2 quart of atf
screwdrivers
2 chairs, you don't know how long you'll be there.
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline jvike
  • Pro-Touring Cuda
« Reply #13 on: April 06, 2008 - 07:17:04 AM »
I have an amplifier and a first-aid kit in my trunk!
Offline cudadave72
  • you motorboatin sob!!!
« Reply #14 on: April 06, 2008 - 08:22:47 PM »
Well I learned my lesson today. Took the Cuda out today to cruise out to the Charlotte Auto Fair. Started fine in the garage. Got to the gas station and----no start!!! :swear: Went to check the battery and sure enough the negative battery post was loose. Two things that would have been very usefull at the moment would have been a 1/2 wrench and a set of jumper cables none of which I had. I had my Cuda all shined up looking nice and like a dummy I was going around asking people if someone had jumper cables. I felt like an idiot!!! :'(
« Last Edit: April 06, 2008 - 08:25:44 PM by 72cuda416 »
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
