kickdown not working on my 727 trans
Author Topic: kickdown not working on my 727 trans  (Read 1219 times)
Offline scf100
  • FAST LANE FOREVER!
« on: April 05, 2008 - 04:55:10 PM »
1970 Challenger that now has a 1972 400 in it....newly rebuilt 1970 727 trans, 600cfm Eldo carb...
adjusted but still will not kick down in passing gear...
could it be inside the trans or do I have kickdown linkage probs?
1970 Challenger R/T convertible 383…. 4-speed…3.91 suregrip
Triple Black
Offline 422STROKER
  • Member Since 6/3/06
Re: kickdown not working on my 727 trans
« Reply #1 on: April 05, 2008 - 05:00:50 PM »
Did this trans ever have a PTKD?  I have an old article about swapping it in to the older transmissions.  I think it wasn't standard until 1972 or so.
I'm sure that Terry will chime in.
Tom :2thumbs:
Tom
Offline scf100
« Reply #2 on: April 06, 2008 - 09:19:22 PM »
Tom :2thumbs:
whats a PTKD?
Triple Black
« Reply #3 on: April 06, 2008 - 09:23:32 PM »
PTKD  part throttle kick down.....yes it would
Offline tactransman
« Reply #4 on: April 06, 2008 - 10:01:52 PM »
Post some pics of your set up and we can help you out.  :cheers:
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #5 on: April 06, 2008 - 10:03:11 PM »
Terry-tactransman
Union, Mo.
Offline scf100
« Reply #6 on: April 07, 2008 - 08:36:00 PM »
pic
Triple Black
Offline 422STROKER
« Reply #7 on: April 07, 2008 - 08:39:11 PM »
Looks like you need to adjust the KD rod at the top there.  Twist the rod till it is up against the carb stud.  If You can't get it that far out either weld it or add a Nut and bolt to get it there.
Tom
Tom
« Reply #8 on: April 07, 2008 - 08:39:42 PM »
I would bet you need to unscrew the slide out quite a bit more, looks like an adjustment is needed. Tact will be the pro for you. I'm seat of the pants and my seat isnt in your car....
« Reply #9 on: April 08, 2008 - 04:35:23 AM »
There should be no gap where the kickdown linkage connects to the carb stud. You seem to have about an inch to move the linkage forward. Apparently the return spring on the linkage is not doing it's job or the linkage needs moved forward.
