Author Topic: A little duct tape should fix it.  (Read 735 times)
Offline 6packCuda
« on: April 05, 2008 - 06:55:43 PM »
Had something kind of scary happen today. I was cruising down the highway in my 2000 F150. I lightly applied the breaks to slow down for an upcoming turn, and all hell broke loose. Lots of grinding and squealing sounds coming from the front end. So I immediately slowed down to find a good spot to pull off the road. Just as I was turning into a driveway I felt the right front of the pickup fall down on the ground. I assumed my wheel fell off. When I got out, this is what I found...
From what I can see, the lower caliper bolt fell out. I think when if fell, the wheel flipped it up and wedged it between the caliper and the wheel. The bolt acted as a pizza cutter and cut the wheel in half as it turned. I think the bolt must have initially hit with enough force to put a hole in the wheel and started a crack. I'm just glad the wheel didn't split while I was doing 60mph.
Re: A little duct tape should fix it.
« Reply #1 on: April 05, 2008 - 07:06:24 PM »
Thank God you are ok.   That was terrible, glad you werent going fast. Did it give any signs first like any kind of noise
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: April 05, 2008 - 07:07:01 PM »
OMG that would be a scary thing to happen.  Dammn!!  Looks like this weeks garbage is going to be alittle heavier.  :22yikes:
« Reply #3 on: April 05, 2008 - 07:09:46 PM »
No not the garbage, aluminum scrap is peaking high :2thumbs:
Offline 6packCuda
« Reply #4 on: April 05, 2008 - 07:17:28 PM »
Absolutely no signs or noises until I applied the brakes.
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #5 on: April 05, 2008 - 08:03:28 PM »
Wow!  That could have been a real disaster!  Thankfully you are alright.  Darn ferds...
« Reply #6 on: April 05, 2008 - 08:14:27 PM »
 "Quality Is Job One"?
« Reply #7 on: April 05, 2008 - 08:19:56 PM »
As I see it. It's a 2000 model. I am thinking it was a mechanics negelect error after a (break) job and maybe not the manufacturer. Today, everyone works for money,so it seems. Thier bills are so high they go for the dollar and not the quality,even when lives are at stake. I'm a stickler for grading my work. It has to be right. Cept for cosmetics, everyone who knows me will tell you that. But it will stay together.
Again, glad your ok
Offline GoodysGotaCuda
« Reply #8 on: April 05, 2008 - 08:32:21 PM »
holy cow! lucky man nothing else happened!
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #9 on: April 05, 2008 - 08:41:43 PM »
 :22yikes:  :scared:  Wow!  Glad you're  okay!!!  :thumbsup:
That looks like it might need 2 rolls of duct tapeactually!  :roflsmiley:
I can relate to this in that when I started out being a mechanic a long time ago, I forgot to tighten up a caliper bolt also and it fell out but it didn't cause the damage like it did in your case.
Glad your okay!  :thumbsup:
