Author Topic: Rocker panel and rear window stud locations  (Read 1115 times)
« on: April 06, 2008 - 04:26:51 PM »
Need a couple pics.
1. Stud mount locations for clips on rocker panel.
2. Rear window stud locations for trim clips.
Re: Rocker panel and rear window stud locations
« Reply #1 on: April 08, 2008 - 11:48:50 PM »
So what I'm asking is how did the factory put the rocker trim on below, Those little studs? and if so, the locations?
Anyone with some pics?
I have access to the stud gun this week end.
PLEASE??
« Reply #2 on: April 09, 2008 - 01:21:23 AM »
My car had holes because it was a Gran Coupe. But I have the thin strip trim now to put on instead. I just need a pick on the side of a car that has the studs with the trim off. If thats the way they did it. Or were the clips screwed in holes?
I suppose I could just put them on randomly guessing. But I really don't like to resort to that if I can avoid it.
Offline bentpshrods
  • Almost there, Boise Id.
« Reply #3 on: April 09, 2008 - 11:37:17 AM »
   Topcat---I just pulled my trim off a couple of days ago.  I went out to get some pic. but the batteries went dead. I will post those pics later today after I get back from the store.
Offline ntstlgl1970
  • T a c o c a t
« Reply #4 on: April 09, 2008 - 01:16:40 PM »
The trim for the rear glass, they were screw in clips not studs. I have a grand coupe also so I can't help on the rocker placement, I'm not sure it really matters though, as long as the moulding ends up level and in the right position. There were 3 screw holes on mine on the front fender end of the trim (in the body not the trim) where it looks like they repositioned it a few times on the assembly line to fit right. I found this image of the rocker panel detail where holes are used (even though it shows pic of a challenger). I also included a pic of where the clips went on my rear window trim, we noted the locations of the clips when we replaced the rear window channel. I had clips and staples on the upper window opening (that still had vinyl under them), maybe you are seeing staple remnants?  :dunno:
« Last Edit: April 09, 2008 - 03:57:40 PM by ntstlgl1970 »
« Reply #5 on: April 09, 2008 - 02:52:00 PM »
On the rear window, I have studs at the roof line. but then the sides are holes. I don't know if those were broken off studs or if they were screw in clips. I'm guessing screw in clips on for sides. Your picture certainly helps alot though Eric thanks.  :2thumbs:
Excellent and very appreciated. Thanks  :2thumbs:
Offline bentpshrods
« Reply #6 on: April 09, 2008 - 02:53:50 PM »
  Here's the rocker trim pics.  The first hole on each end is a screw and then the studs. Going from the rear wheel fender lip edge towards the front----lip to screw--2".   Lip to first stud---10".  First stud to second stud 4.5 "   Then the 2-3-4-5-6 are spaced 9 3/4 " apart.  They are 1/2 or 5/8 " from door sill down to stud.  Were you able to buy new clips?  If so where did you get them from.
« Reply #7 on: April 09, 2008 - 05:33:49 PM »
I bought the trim when it was still available as OEM NOS with the clips. And they're all still good and re usable. I would've never guessed that 2 of the studs were so close with each other. Thanks once again.   :2thumbs:
Hoover auto parts I think stocks those clips right now. I'm pretty sure of that. You'll have to double check it out though.
« Reply #8 on: April 14, 2008 - 10:16:49 PM »
Did you find them yet?
Let me know if you haven't I know I recently saw them on one of the websites I keep in all my favs.
