Author Topic: 741/742/489 case  (Read 1413 times)
nivvy
741/742/489 case
« on: February 28, 2004 - 09:29:01 AM »
Is anyone better than the other?
thx
Offline heminut
Re:741/742/489 case
« Reply #1 on: February 28, 2004 - 11:01:42 AM »
The 742 is generaly regarded as the best. The 741 has a 1&3/8" pinion as opposed to the 742"s 1&3/4" pinion. The 489 has a 1&7/8" tapered pinion, which is actually larger than the 742's, but it uses a crush sleeve instead of shims to set the pinion bearing preload. This is less desirable on a high horsepower application due to the fact that the crush sleeve can collapse more, allowing the bearing preload to change. Most rear end companies now have a kit that uses a solid sleeve to replace the crush sleeve in the 489 and shims to set the bearing preload just like you would with a 742.
For most street applications any one of the three carriers will work fine if set up properly.
1970 5.7 Hemi Cuda
