Author Topic: What do you wrap your Engine Harness with?  (Read 3335 times)
Offline wally426ci
    • maryland mopars
« on: April 07, 2008 - 12:12:09 PM »
I always heard Electrical tape was wrong. I have been using Friction Tape b/c that looks close to original for me, But it has the habit of getting gummy and getting residue on the paint under the hood. Is there something better out there?
 :popcorn:
 :feedback:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Kapteenikosmos
Re: What do you wrap your Engine Harness with?
« Reply #1 on: April 07, 2008 - 12:29:22 PM »
I'm using this kind of cable "cover" :
https://www1.elfa.se/data1/wwwroot/webroot/Z_DATA/fba1ba80-797f-11dc-9199-0019bbdf5d02.pdf
It's pretty much same kind of stuff that the factory used on the rear wire assemblies, only difference is that the original was somekind of fabric and this stuff is plastic.
Only problem is that you need to remove contacts from either end to install it and this still needs some taping where the wires separate from the main "bunch".
It isn't a big problem for me because I'm replacing all engine wires and only keeping the plastic housings. I even accuired few bags terminals used in these wires.
I've also heard good things about 3M super 88 (or something like that) tape which is somewhat more expensive than the chinese tapes in the market and this one should be resistant to oils.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline ntstlgl1970
  • T a c o c a t
« Reply #2 on: April 07, 2008 - 12:34:14 PM »
There is a non-adhesive vinyl tape made for harnesses, I have some. I'll look and see if it has a name brand on it. I bought it from a shop a few years ago.
Offline matt63
« Reply #3 on: April 07, 2008 - 06:26:00 PM »
I've been looking for the non-adhesive vinyl tape but I haven't seen it around for a couple of years.  I usually use electrical tape but I bought something new today.  It's a woven tubing available in 1/4 inch diameter up.  Painless Wiring has it although I bought a no name brand.  It looks better than plastic loom.  I might not be able to use it on the existing wiring but I have added alot of new ones which could be made to look better.
Matt in Edmonton
'68 Valiant
Offline gkring
« Reply #4 on: April 07, 2008 - 06:40:22 PM »
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemType=PRODUCT&RS=1&itemID=1391&keyword=25063&cm_mmc=undefined
This type is for the original look, but I prefer the nonadhesive vinyl only wrap for a minimum amoutn of mess down the road when having to add wiring or diagnose issues.
Greg
1970 Barracuda driver
Offline wally426ci
    • maryland mopars
« Reply #5 on: April 08, 2008 - 08:43:46 AM »
 :2thumbs:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline PlumCrazy
« Reply #6 on: April 08, 2008 - 11:10:22 PM »
Correct wrap.
Offline NoMope Greg
« Reply #7 on: April 09, 2008 - 12:31:01 AM »
Correct wrap.
Great!
What's it called and where can we find it?  'Cause it looks like electrical tape. ???
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline PlumCrazy
« Reply #8 on: April 09, 2008 - 02:07:43 PM »
Great!
http://www.wiringharness.com/harnesstape.htm
Offline 71340RT
« Reply #9 on: April 10, 2008 - 12:34:49 AM »
I used the non adhesive vinyl tape from R/T Specialties and if you ever have to find a problem in the harness you will be glad you used the non stick stuff.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
