Do you need new drum backing plates? I do remember mentioning your rubber brake hoses. Probably be a good time to change those out since you need to flush the brakes (front & rear). dont ask me how i know!!!
As always, you need a hand, lemme know. I can probably borrow the pressure brake bleeder from work which makes things easier (i need to flush the fluid in my truck anyway). I do have some of the drum brake tools (though no standard line-wrenches which are important since you're reusing the hardlines). I've done mine, but they are still always fun to too
Maybe i should drive my car this time for easy comparison if need be
Now would be a good time to use some PB-Blaster, WD-40, etc on the brake line fittings at all rubber hoses, and at the back of the wheel cylinders every couple days. So when you get to taking it apart, hopefully...HOPEFULLY, all the line fittings pop right loose.
