Author Topic: Harmonic Balancer  (Read 1227 times)
Offline 71chmark
Harmonic Balancer
« on: April 10, 2008 - 08:06:17 AM »
Please tell me the TDC timing line on my 440s balancer is recessed so I can find it since some fool (me) painted over everything. I also assume the hole in the plate sticking out from the timing chain cover is zero degrees (although it is off center.  How many degrees and which direction are the lines on either side of the hole?  Some fool (yes me again) painted over that also.  Thanks so much for your time.
I may be schizophrenic,
Re: Harmonic Balancer
« Reply #1 on: April 10, 2008 - 01:26:56 PM »
yes there is a slot in the damper @ TDC & yes the hole is TDC also , you never need Atdc so it is the short side the BTDC goes 20* or so
