Author Topic: Replacing axle seals  (Read 853 times)
Offline wally426ci
    • maryland mopars
« on: April 11, 2008 - 09:10:01 AM »
do you guys use that little alter boy bell looking tool? or is there another way, i was thinking of replacing my axle seals since i hadnt when i put the axle bearing in on the passenger side.  :bigshades:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline MJB
Re: Replacing axle seals
« Reply #1 on: April 11, 2008 - 10:20:00 AM »
I made a tool using a heavy threaded rod, large thick washers and nuts.  It worked pretty well but probably not as well as the real thing??
Offline quagmire
  • Traction Impaired......
« Reply #2 on: April 11, 2008 - 09:28:14 PM »
I just use a hammer to drive a screwdriver through old seals and twist it to pop it out.  You could also try a screwing a sheetmetal screw into it and pulling it out with a slidehammer or pliers.
Offline wally426ci
    • maryland mopars
« Reply #3 on: April 12, 2008 - 08:34:19 AM »
googadeegoogoogoo .... quagmire  :roflsmiley:
Thanks, but im really just concerned with getting the new ones in. i thought you had to drive them in....
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline quagmire
« Reply #4 on: April 12, 2008 - 07:42:43 PM »
Ha ha! Thats exactly where I got that screen name from!  Yes, you need to drive them in.  You can buy a seal driver tool set from most parts stores, or find a length of pipe from a hardware store that fits the outside diameter closely.  Be really careful to not drive them in too far, or you will distort or cock the seal.
Offline wally426ci
    • maryland mopars
« Reply #5 on: April 13, 2008 - 07:47:06 AM »
ahhhh, i see. thanks. I just havent driven one in before and was unsure of how much of a task it would be. Thanks!!  :bigsmile:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
