Handling and Sub-Frame Connectors...... Opinions / Advice Please???
Author Topic: Handling and Sub-Frame Connectors...... Opinions / Advice Please???  (Read 2986 times)
Offline Haney
What are your thoughts on sub frame connectors for improving handling?  I am building a 1973 Cuda that will not be a strip car but a driver.  It is going to be a mild 440, 4-speed car that I am not looking to make a HP monster out of, but I would like for it to handle well.  It will have a new leaf spring rear suspension, stock rear sway bar, new poly front suspension, stock front sway bar, tubular upper control arms, 0.960 torsion bars, and a 16:1 ratio manual steering (either firm feel or flaming river).
Will sub-frame connectors help the handling?  Will it help it enough for the $$ and labor involved to install?  I am looking at the contoured type from US CAR TOOL.
Thanks for your thoughts…..
« Last Edit: April 11, 2008 - 11:01:05 AM by Haney »
1969 Barracuda Coupe, 340, 4-speed
Offline hemiken
Re: Handling and Sub-Frame Connectors...... Opinions / Advice Please???
« Reply #1 on: April 11, 2008 - 10:51:10 AM »
They are an absolute must in my opinion.  Much nicer feel on the road and something Ma Mopar should have done from the factory.
 :2thumbs:
Offline RusTy/SE
  • Just havin' fun
« Reply #2 on: April 11, 2008 - 10:55:52 AM »
I plan on having them installed on my 440-4 (.030) R/T SE. Mild cam, polygraphite suspension kit, original front sway bar, no rear sway bar. Total street and long distance use :thumbsup:
http://www.uscartool.com/Eframeconn/index.html
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
« Reply #3 on: April 11, 2008 - 11:11:44 AM »
I agree it is a worthwhile addition
Offline ntstlgl1970
  • T a c o c a t
« Reply #4 on: April 11, 2008 - 12:26:30 PM »
You will notice the difference the first time you go over a speed bump or go into/out of your driveway (assuming you have a curb "hump" for the gutter. I would consider it essential for any unibody car that you wish to make handle better. The suspension is only as good as the platform you put it on. I'm sure HP2 will chime in with better info as to why.
Offline Haney
« Reply #5 on: April 11, 2008 - 12:37:39 PM »
Thanks for all the repies so far....  Looks like it is the thing to do......
nivvy
« Reply #6 on: April 11, 2008 - 12:47:53 PM »
X2 - My car rides alot better now... also I think lowering the car a couple inches helped as well...... :2thumbs:
Offline drewcrane
« Reply #7 on: April 11, 2008 - 04:18:38 PM »
i have the xv sub frame connectors as they form fit to the floor pan with a little grinding, they make a huge difference, its a different car!you have to pull the seats to do the welding,it gets hot but it totally tightens up the floor , if you stomp your foot on your floor noww it sounds kinda like a bell, when i put these on it has a solid thud , they help make the car a little safer in case of side impact, yes well worth it! :horse: :cooldancing:
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #8 on: April 11, 2008 - 05:26:50 PM »
Take the time and install them.  :bigshades:
Go Fast & Have Fun...
Offline Aussie Challenger
« Reply #9 on: April 12, 2008 - 07:20:12 AM »
  Anything that stiffens up the body will help to transfer the torque better to the rear wheels.   :burnout:  Otherwise the body absorbs this extra twisting effect, and the rear wheels miss out. On a car doing a road course it allows better control of weight transfer.    :bananasmi
« Reply #10 on: April 12, 2008 - 09:46:51 AM »
IMO they are a must, even for a car that only gets street miles.
Think of it this way; A uni-body car is like a shoe box with a lid. The lid keeps things from moving too far, but things can still move around a little bit within the confines of the lid as it twists and lifts. If you tape the lid down, similar to adding subframe connectors, the twist and distortion becomes greatly diminished and rigidity is greatly improved. Rigidity is necessary to allow the suspension to properly function at suspending the car. If the car is flexing, you turn the whole body into a variable of the suspension that you cannot control.
If you want to see the results they provide, before you put them in put a floor jack under one of the front control arms, and crank up that corner. Then open and try to close the door. It ain't easy if it even closes at all. After the sub frame connectors are in, try it again and observe the difference.
In terms of strength, even the bolt in, tube style that don't attach to the board will yield dramatic improvements, especially if you weld the ends. The next step up are the contoured weld in units, then through the floor weld in.
For a street car you will immediately notice a reduction in the squeaks and rattles of normal driving. Turn in and cornering becomes more stable, and if you ever do launch away from a stop light, it is straighter and more predictable.
DO IT!!
« Reply #11 on: April 14, 2008 - 07:25:21 AM »
  HP2  a good explaination, should make it easier for some.   :2thumbs:
Offline Haney
« Reply #12 on: April 14, 2008 - 12:36:23 PM »
WOW!  Sounds like a no brainer.....   All the interior is still out of my car so now is the time to do it....  I will be adding the SF Connectors!   Thanks for all the help and input!
Offline 74 340 4speed
« Reply #13 on: April 14, 2008 - 08:39:22 PM »
I've been wanting to buy a set for my cuda too.  Who makes the best fitting subframe connectors?  I do not want to cut my floor pans, or have to cut the connectors to get them to fit correctly.  I put a set of weld in competition engineering subframe connectors in my 67 Camaro and they made a huge difference in the way the car handles.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline BIGSHCLUNK
« Reply #14 on: April 14, 2008 - 08:42:30 PM »
They're on my "do eventually" list!  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
