Well, it was the only wire that was reading voltage... I was getting a little over 11 Volts from the Dark Blue.
Heres my hook up: i have Dark Blue, Next to Light blue with yellow stripe and a jumper @ the Ballast resistor.
Then i have the 2 wires together on the other side and the single wire next to that.
I will say that, when i connected the new wire, i took everything off and re-did all connections to the ballast resistor. I just dont get it......
And i just used the solder that came with the gun from Home Depot, it says its for electrical....
