Author Topic: Soldering & the Ballast Resistor BlueHooHoo's  (Read 9112 times)
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #15 on: April 13, 2008 - 07:33:58 AM »
where it comes up out of the main harness, parallel to the light blue with yellow. are there any other 12volt sources? I mean i'll figure this out, maybe i just need to make a better connection ..........  :banghead:
:dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Soldering
« Reply #16 on: April 13, 2008 - 08:44:03 AM »
Since the splice have you checked the voltage with a meter?  This just should not be a problem, I'm still wondering if the problem is somewhere else. Could anything else have been effected?
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #17 on: April 13, 2008 - 08:45:40 AM »
actually i havent, i will check and see. Im also gonna clean all of my connections up too. Good idea!  :2thumbs:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #18 on: April 13, 2008 - 09:02:09 AM »
Ok im definitely getting the same voltage as when i started out. about 11.10-11.20
i didnt unhook anything else, its just rediculous. The car won't stay running. it just keeps wanting to die.  :1zhelp:
kill me now.  ???
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Soldering
« Reply #19 on: April 13, 2008 - 09:16:33 AM »
Have you tried electrically disconnecting the choke from the circuit?  I guess to start the car you would have to manually manipulate your choke plate...... just brainstorming.   :-\
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #20 on: April 13, 2008 - 09:48:33 AM »
Thanks for thinking with me. Ive tried that, i just cant figure it out. At the time of start up, the choke is closed even with the wire ooked up b/c of spring tension. The car starts up now like it isnt choked, when it is.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Soldering
« Reply #21 on: April 13, 2008 - 09:57:27 AM »
Does the choke open a little immediately after start up?....On the OE setup a vacuum diaphragm pulls the choke open a smidge...if it didn't the engine would starve for air & die.
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #22 on: April 13, 2008 - 10:37:18 AM »
Yeah, it opens a little, i even unhook it and it still wont run right.  :popcorn: im gonna get some contact cleaner later on and mess with it. if that doesnt work, i'll open up my solder areas and check it out.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Soldering
« Reply #23 on: April 13, 2008 - 01:04:06 PM »
Does the choke ever open up all the way? Just sitting there with the key in the "on" position would do this. If it never opens up all the way, that's your problem.
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #24 on: April 13, 2008 - 01:57:44 PM »
Well, i even unhooked the rod that operates the choke and it still acts up. I will get to it this week and give some feedback on results.......  :chatting:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Soldering
« Reply #25 on: April 13, 2008 - 02:14:10 PM »
This is what I would do... Disconnect the wire to the ballast resistor. Make a jumper wire to run from your battery + to the ballast. Start the car ...if the problems go away you know for sure it's in the wiring...if not you know your problems are elsewhere, ignition, carb.
Re: Soldering
« Reply #26 on: April 13, 2008 - 06:13:17 PM »
Wally,
  You are killing me here.  :pullinghair:  I'm up for a road trip. PM me your address and a time if interested.
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #27 on: April 13, 2008 - 09:03:45 PM »
 :roflsmiley:
you're too funny. if i dont have it figured out this week, i'll be counting on you for a weekend trip!! Thanks! i'll send you my address  :bigshades:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Aussie Challenger
Re: Soldering
« Reply #28 on: April 14, 2008 - 07:50:49 AM »
  Yes jump a wire from the battery to isolate the rest of the circuit, 11 volts is to low in the real world, check your bulk head connector, the voltage at the positive terminal on the alternator and last but not least the voltage drop across the AMP guage. You should have at min. with engine not running 12.5volts, about 13.8 volts with engine running. I have had to change a few wires and terminals on my Challenger to achieve the desired voltages, and yes I have soldered every terminal that I can.
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #29 on: April 14, 2008 - 07:53:33 AM »
I bought some contact cleaner yesterday, i plan on wrenching after work. Its so nice out, i just want to drive!! im so impatient though, it all takes time....  :popcorn:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
