Author Topic: Soldering & the Ballast Resistor BlueHooHoo's  (Read 9113 times)
Offline 422STROKER
  • Member Since 6/3/06
Re: Soldering
« Reply #30 on: April 14, 2008 - 08:02:24 AM »
Don't forget to disconnect the battery before you start spraying and brushing. :22yikes:
Tom :2thumbs: :smilielol:
Tom
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #31 on: April 14, 2008 - 09:28:17 AM »
 :smilielol: thanks!
you know i was thinking, if i jump the 12volt, that will only solve half of the connection since there are 3 wires on the other side of the ballast resistor. Im hitting it hard after work so hopefully i report back with good news.  :cheers:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Soldering
« Reply #32 on: April 14, 2008 - 09:44:54 AM »
Well the jumper eliminates the supply side of the equation to the ignition.
Like I said IF there are other issues this will isolate them.  :thumbsup:
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #33 on: April 14, 2008 - 10:46:29 AM »
Oh bullitt, where have you been my whole life?  :dunno:
 :roflsmiley:
 :bigshades: I'll report back.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Soldering
« Reply #34 on: April 14, 2008 - 01:49:56 PM »
Figgurin out problems that the " factory trained" guys here can't
   longer than you've been alive       :smokin:
« Last Edit: April 14, 2008 - 01:54:19 PM by bullitt99 »
Re: Soldering
« Reply #35 on: April 14, 2008 - 05:59:01 PM »
    :iagree:   :iagree:   :iagree:
Don't you just hate these young guys?   :stirpot:
Offline wally426ci
    • maryland mopars
Re: Soldering
« Reply #36 on: April 15, 2008 - 07:25:30 AM »
Hey wait a minute......... ok anyway, i messed around a little yesterday making better connections. No change!  :pullinghair: Im getting about 15volts with the car running so i dont think its that. I failed to mention that i changed out my ballast resistor plugs with a junk yard set so i would have longer wires to work with. could that be it?  :banghead: the car has a bad miss to it. I was thinking of changing these wires out and not using the plastic plugs for now just to figure it out. I stomped on it in front of the house (got the finger from a neighbor a few blocks down  :misbehaving: ) i got mine when the car died at the stop thing and then it really runs terrible, i have to keep my foot on the gas?!?!?!  :faint:
 :1zhelp:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Soldering & the Ballast Resistor BlueHooHoo's
« Reply #37 on: April 15, 2008 - 08:12:52 AM »
Are you sure you didn't do something to the carb when you installed the electric choke? The problem could still be an electrical issue though. I guess I narrowed it for you.   :misbehaving:
« Reply #38 on: April 15, 2008 - 08:37:48 AM »
   The plot thickens   :popcorn:
« Reply #39 on: April 15, 2008 - 08:47:23 AM »
To make it even muckier, I would assume he took the carb off to put the electric choke on. If he now has a vacuum leak, that would explain why it won't stay running while in gear.   :dunno:
Offline wally426ci
    • maryland mopars
« Reply #40 on: April 15, 2008 - 08:56:57 AM »
Ah, well i was careful and successfully installed it while on the car. I also had the choke assembly on there for a few weeks before i connected the wire. So, it ran fine until i opened this can of worms. does someone reproduce the ballast resistor 4 plug with wires connected???
i feel like a fool on this one, maybe i dropped a peice of electrical tape in the carb or something. i dont know anymore.
its so nice out, i hate to leave it parked for such a long time!  :working:
very frustrated.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #41 on: April 15, 2008 - 09:02:42 AM »
Any chance that the wires are switched going to the ballast....I'm not sure what the outcome of doing this would be but I would assume not good.
Offline wally426ci
    • maryland mopars
« Reply #42 on: April 15, 2008 - 09:05:24 AM »
well i dont figure that side to side would matter since theres a jumper with the dk blue and light blue yellow stripe
does anyone have a wiring diagram of this??
is there a difference between the 2 sides??
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #43 on: April 15, 2008 - 09:27:04 AM »
....yea I guess there's no dif. on the input but there is on the output
« Last Edit: April 15, 2008 - 09:30:05 AM by bullitt99 »
Offline wally426ci
    • maryland mopars
« Reply #44 on: April 15, 2008 - 10:01:45 AM »
 :sly: we need a chin-rubbing smiley......
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
