Author Topic: Soldering & the Ballast Resistor BlueHooHoo's  (Read 9109 times)
Offline wally426ci
    • maryland mopars
Re: Soldering & the Ballast Resistor BlueHooHoo's
« Reply #45 on: April 15, 2008 - 10:02:49 AM »
are there any diagrams out there with wire colors? i have a 71 book, so obviously that wont work
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #46 on: April 15, 2008 - 10:45:53 AM »
I guess '73 was the 1st year for electronic ignition?!?!    FWIW
http://www.mymopar.com/downloads/1973/73ChallengerA.JPG
Offline wally426ci
    • maryland mopars
« Reply #47 on: April 15, 2008 - 11:24:41 AM »
had some fun with paint...... not that it helps much, well maybe it does :P
« Last Edit: April 15, 2008 - 12:22:21 PM by wally426ci »
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #48 on: April 15, 2008 - 12:08:21 PM »
To make it even muckier, I would assume he took the carb off to put the electric choke on. If he now has a vacuum leak, that would explain why it won't stay running while in gear.   :dunno:
 :iagree:  That happened to me a couple of months ago.  Ran crappy, stalled under 2000rpm.  Had a small vacuum leak due to a cracked hose at the rear base of the carb going to the air filter housing.
Not that this is the issue but something to think about...
« Reply #49 on: April 15, 2008 - 01:35:49 PM »
actually 72 was the first year for electronic ign as na option , 73 it became std equipment
Offline wally426ci
    • maryland mopars
« Reply #50 on: April 15, 2008 - 01:44:24 PM »
Neil, im still waiting for you to rub a magic wand over my car.......  :popcorn:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #51 on: April 15, 2008 - 02:10:49 PM »
I could drop by but would I be safe in your neighborhood ??
Offline wally426ci
    • maryland mopars
« Reply #52 on: April 15, 2008 - 02:42:47 PM »
  :stirpot: all depends on your complexion. you may wanna lay out for a while......  :icon16:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Kapteenikosmos
« Reply #53 on: April 15, 2008 - 03:07:57 PM »
I would also suspect that it has nothing to do with the electrical repairs you did. Most likely something else just decided to give up and causes these symptoms. Once, I installed a new (old) carb to our six banger Mustang and after the installation it ran very rough or not at all. Before the change it worked almost flawlesly. Well you can guess how many hours I put on the carb to check and recheck everything on it and later found that the condensator from the points type ignition decided to give up at the same time and caused all the problems.
Keep checking for everything that you haven't touched, which could cause same symptons, and I guess that you will find the problem  :cheers:
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
« Reply #54 on: April 15, 2008 - 06:36:16 PM »
Wally,
  Do you have electronic ignition?  I swear...if this ends up being a clogged fuel filter...  :horse:   :horse:   :horse:
« Reply #55 on: April 15, 2008 - 08:27:23 PM »
Nice .....you gonna copyright your work?
Offline RusTy/SE
  • Just havin' fun
« Reply #56 on: April 16, 2008 - 12:10:39 AM »
I'm way outta my league here, but is the coil ok?
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #57 on: April 16, 2008 - 03:00:36 AM »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline wally426ci
    • maryland mopars
« Reply #58 on: April 16, 2008 - 07:43:37 AM »
I have electronic ignition. is it possible that the soldering gun heated up a wire too much and created problems up or downstream????
 :dunno:
and thanks for the pic!!!!  :2thumbs:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline ChallengerHK
« Reply #59 on: April 16, 2008 - 09:21:11 AM »
They definitely recommend that you unplug things before soldering. How close were you working to anything that could have been damaged, like the ballast?
- Han Solo, Star Wars
