Author Topic: Soldering & the Ballast Resistor BlueHooHoo's  (Read 9108 times)
Offline wally426ci
    • maryland mopars
Re: Soldering & the Ballast Resistor BlueHooHoo's
« Reply #60 on: April 16, 2008 - 09:48:27 AM »
well, i had the ballast resistor unplugged but no the ECU....... the wires definitely got HOT !!  :bricks1:
but would a damaged ECU cause these running conditions?  :clueless:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #61 on: April 16, 2008 - 10:37:29 AM »
Think you would have melted a lot of insulation before enough heat was built up in the wires to damage to ECU...
Offline ChallengerHK
« Reply #62 on: April 16, 2008 - 11:10:30 AM »
The only place that would probably be likely would be the ECU because of the transistors.
Even then, though, I think this line of reasoning is a long shot.  :dunno:
- Han Solo, Star Wars
Offline wally426ci
    • maryland mopars
« Reply #63 on: April 16, 2008 - 11:55:37 AM »
hmmmmm  :clueless:
havent had any time this week, i will get back to the problem this weekend. I appreciate everyone berring <(spell?)with me through 5 pages
 :cheers:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline hemiken
« Reply #64 on: April 16, 2008 - 11:59:22 AM »
Hey Wally, i'd like to help you out buddy................ but every time i look at some wiring i think :clueless: Hmmmm some meatballs and some tomato bolognaise sauce and i could have a real-a tasty-a meal right-a their :drool:
 :smilielol: :2thumbs:
Offline wally426ci
    • maryland mopars
« Reply #65 on: April 16, 2008 - 01:57:56 PM »
 :smilielol:
me too.......  :misbehaving:
maybe it will work out the kinks if i spread some Ragu on it....  :cooldancing:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #66 on: April 16, 2008 - 06:28:10 PM »
Transistors aren't fond of heat. Notice the heat sink on the biggie on your ignition module. I don't think it's the ignition module though. That would either be good or bad, not a half-way good type of thing. The coil is another story. I had one half alive. UGH!! This could be as easy as a loose spark plug wire.   :pullinghair:
Offline ntstlgl1970
  • T a c o c a t
« Reply #67 on: April 16, 2008 - 08:08:06 PM »
Just wondering if there is something else going on. if you can keep it running long enough with the hood up/air cleaner off, shoot some carb cleaner or brake cleaner down the carb and see if the idle smoothes out, wondering if you induced a vacuum leak somehow (PCV valve/hose something)
Offline wally426ci
    • maryland mopars
« Reply #68 on: April 17, 2008 - 07:26:37 AM »
im gonna wrench on saturday morning.... got some things to do tonight and tomorrow....  :working: i'll let you guys know.. now i have a few things to check. how could i be such a fool to not unplug everything!! i suppose you only live once and learn from mistakes....  :misbehaving:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #69 on: April 17, 2008 - 12:42:35 PM »
I Have never unplugged everything when adding a simple wire to the choke
Offline wally426ci
    • maryland mopars
« Reply #70 on: April 18, 2008 - 07:41:42 PM »
Mike, it isnt the fuel filter  :grinno:
Maybe i should post this in "what is it?"  :lol:
Ok, so we're going to dinner soon, so i will run back through the wiring tomorrow morning. If there is no problem there, then i will mess with the carb. Im only assuming its wiring since thats all i changed. we will see.
 :bricks1:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline wally426ci
    • maryland mopars
« Reply #71 on: April 19, 2008 - 02:23:00 PM »
SOLVED!  :2thumbs:
I reconnected all of my ballast resistor wires with new wiring and regular flat connectors, so dont laugh when you see that at a show.... but anyway, the only difference in configuration was: the junk yard connector had the blue with yellow tracer going all the way to the dk blue side of the resistor ,previously i had that intrercept earlier in the dk blue wire.
So, i am back where i started, i need to connect the choke wire (i connected w/o this time for problem solving)
This time, im gonna just start with only that wire and leave all else alone.  :working:
I wanna cruise, but at the same time, im a perfectionist. so, i really want to get new headers and repaint the engine bay before it sees much daylight..... and some other things, like rewrapping the harness, put my new Made In USA plate on to replace the original faded one, repaint all my cadmium parts, quieter mufflers, and some other things...
 :woohoo:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Kapteenikosmos
« Reply #72 on: April 19, 2008 - 03:06:22 PM »
Way to go!  :thumbsup:
The electrical gremlins can be a real pita!
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
« Reply #73 on: April 19, 2008 - 05:22:45 PM »
It's summer time, leave the choke alone for a while and go cruise. You will have all winter to post a 15 page question essay on how to hook up an electric choke :roflsmiley:
Offline wally426ci
    • maryland mopars
« Reply #74 on: April 19, 2008 - 05:36:20 PM »
 :smilielol:
Funny thing is, no matter what time of year, she always needs help running for the first 15mins....
 :dunno:
Otherwise, its time to ride!  :burnout:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
