Author Topic: 70' Cuda Hood Insulation  (Read 1220 times)
Offline longgone
« on: April 12, 2008 - 09:26:36 PM »
My 70' Cuda doesn't have any insulation under the hood.  It has the rallye hood (not shaker, not flat).  Did these come with insulation?  If so, where is a good place to get a repop kit and all the fasteners needed to hold it in place?   :clueless:
Thanks
Blueglow
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
Re: 70' Cuda Hood Insulation
« Reply #1 on: April 13, 2008 - 12:57:05 AM »
The underhood insulation was an option that came with the factory undercoating, I forgot the code for it.  Check and see if your car has factory undercoating, then it came with underhood insulation, if it is painted underneath then no insulation.  I see kits for these on ebay often.
« Reply #2 on: April 13, 2008 - 08:57:31 AM »
Dantes always carries some of the best available products from what I've seen.
http://www.dantesparts.com/hoodpad.html
Offline solarguy
« Reply #3 on: April 13, 2008 - 09:51:29 AM »
If you are going to put it on, get the molded one, not the furry rag that looks like sasquatch.  There is a guy on ebay selling the molded ones with clips for around 60.00.  You can get it with or without the air cleaner cut-out.  I got one and it fits like a glove
