Author Topic: CUDA CHALLENGER 340-360 727 SMALL BLOCK TRANSMISSION PART #3640414  (Read 3378 times)
Offline flmopars
I HAVE AN ORIGINAL SMALL BLOCK 727 TRANSMISSION.PART# 3640414,IT WAS IN A CAR DEAL I PURCHASED,I WAS TOLD IT WAS REBUILT,AFTER REMOVING THE PAN AND INSPECTING THE TRANSMISSION IT DOES APPEAR TO BE REBUILT,IT DOES HAVE A HOLE DRILLED IN THE TOP OF THE BELLHOUSING AREA.
$279.00 plus shipping
Feel free to e-mail me at spoiled2brats2003@yahoo.com about these part or any other parts you might need.
orange park,florida 32065
Re: CUDA CHALLENGER 340-360 727 SMALL BLOCK TRANSMISSION PART #3640414
« Reply #1 on: April 13, 2008 - 07:38:14 PM »
That should be a van transmission. You set the timing through the hole.   :2thumbs:
Offline flmopars
« Reply #2 on: April 13, 2008 - 08:21:40 PM »
No that hole is there to cool the converter if used in a race application. Thanks, Amanda
« Last Edit: April 13, 2008 - 08:29:48 PM by flmopars »
Offline flmopars
« Reply #3 on: April 21, 2008 - 02:36:47 PM »
***ALL REASONABLE OFFERS WILL BE CONSIDERED***
THANKS,AMANDA
Offline Challenger6pak
« Reply #4 on: April 21, 2008 - 02:59:39 PM »
Amanda.  Listen to Al.  He knows what he is talking about and was only trying to help.  Due to the way an engine sits in a van you cannot use a timing light on it like you can for a car.  Mopar put the hole in the transmission case so you could set the timming using the transmission.  To cool a converter you need to cool the fluid inside of it.  You do that with a transmission cooler.
Offline flmopars
« Reply #5 on: April 21, 2008 - 03:57:23 PM »
I guess you can use it for either or.Thanks, Amanda
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #6 on: April 21, 2008 - 04:01:47 PM »
Except that hole won't cool the converter.
1996 Dodge Viper GTS Coupe
Offline flmopars
« Reply #7 on: April 21, 2008 - 04:11:07 PM »
So you can use it for what then? Thanks, Amanda
Offline 72hemi
« Reply #8 on: April 21, 2008 - 04:16:09 PM »
Like was stated above, it's used to set the timing.
Offline flmopars
« Reply #9 on: April 21, 2008 - 04:39:52 PM »
BUT THE AD CAN STAY THE SAME I DON'T NEED TO CHANGE ANYTHING OR DO I. THANKS, AMANDA
« Reply #10 on: April 21, 2008 - 05:18:10 PM »
Where did they come up with the part number?  It will fit the 273,318,340,or 360 engines.  It will work in a Challenger, Cuda, Road Runner, Charger, van, truck, etc.  The case lets us know it came from a van.  It originally had a plug that went in the timming hole.  Label it however you want or just leave it alone.   What I am seeing here is that they are not giving you the right information to post.  I can see it is not your fault.
« Last Edit: April 21, 2008 - 05:20:49 PM by Challenger6pak »
« Reply #11 on: May 03, 2008 - 08:30:50 AM »
bump
