Author Topic: fender mounted turn signals  (Read 1823 times)
Offline dwbiggs
« on: April 14, 2008 - 03:12:42 PM »
When I got my car painted I took apart the front end...when I went to put it back together I didn't think about the signal lights and now I can't figure out how the pigtails feed through to the harnass.  When I look through the hole where they mount there is nowhere where I can see to feed the pigtail through to the main harness.  Anyone have any ideas, or do I have to take the grill off to do it?
Re: fender mounted turn signals
« Reply #1 on: April 14, 2008 - 03:17:18 PM »
there shoud be a single pin connecter with the connector for the side marker light , if it is routed correctly it will reach
Offline GoodysGotaCuda
« Reply #2 on: April 14, 2008 - 03:59:14 PM »
yep mine were between the grille and the radiator support on each side, near the headlight buckets. the haness will be female single plugs, male side is on the light assembly itself
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline dwbiggs
« Reply #3 on: April 23, 2008 - 11:16:55 AM »
My problem is feeding the wire through to the connection.  I can't seem to find a way through the hole on the fender down to the connection in the harness.  There is a floor if you look through the hole on the fender and I can't see where to feed it.
« Reply #4 on: April 23, 2008 - 12:01:07 PM »
there should be a small hole to route the wiring through into the wheelwell
Offline dwbiggs
« Reply #5 on: April 23, 2008 - 01:56:05 PM »
Thanks, I'll take another look.
« Reply #6 on: April 24, 2008 - 02:40:09 AM »
look inside the wheel well , there should ba a small hole approx 1" for the wiring to go through
« Last Edit: May 01, 2008 - 07:08:27 PM by Chryco Psycho »
Offline dwbiggs
« Reply #7 on: May 01, 2008 - 01:29:55 PM »
Quote
look inside the wherel well , there should ba a small hole approx 1" for the wiring to go through
Thanks!
« Reply #8 on: May 01, 2008 - 07:08:44 PM »
I assume you found it ??
Offline Black340
  • 1973 challenger 340 4 Speed
« Reply #9 on: May 01, 2008 - 07:55:56 PM »
 :popcorn:
