Author Topic: Be Cool Eliminator Series radiators, Anyone run one?  (Read 911 times)
Offline wjaholic
« on: April 17, 2008 - 11:24:54 PM »
I was looking around and found one on sale. They had one that is a direct fit for my '74 Duster. I am planning on running an electric fan on what ever radiator I get.
http://www.jegs.com/p/Be+Cool+Radiators/953884/10002/-1
Quote
"Be Cool's Eliminator series aluminum custom fit radiators will keep you from ever losing your cool again! The Eliminator radiator features a cross flow design using dual 1'' tubes, .080'' thick tanks and billet filler neck. This custom fit radiator easily replaces your old stock unit without any modifications or extra mounting brackets.
Best Performance & Value
Performance Grade Dual One Inch Core
Epoxy Free Construction
Billet Filler Neck with High Capacity Over Flow Tube
Folded & Tapered Tanks
Popular Sizes for Today's Applications
Custom Fit for Flange & Cradle Mounting
Heavy Duty Automatic Transmission Cooler
OEM Size Inlets & Outlets
OEM Style Petcock
100% Pressure Tested
Durable Packaging
Made in North America"
Quote
Sounds good, I know my big block is going to get hot, I am planning on driving it on some hot days So I am trying to plan as far ahead as possible.
Offline cudagirl4406pk
    • Garageartmusclecars
Re: Be Cool Eliminator Series radiators, Anyone run one?
« Reply #1 on: April 18, 2008 - 01:12:29 AM »
I run a becool setup in my cuda the one i run is a crossflow radiator with dual electric fans and i love it but make sure you use the 50/50 antifreeze in the drk gray bottle from prestone the heavy duty and add one bottle of purple ice from royal purple really helps the car stay cool.
michele
