Author Topic: Curious WIW MP 360 Shortblock + Goodies  (Read 903 times)
Offline GoodysGotaCuda
« on: April 20, 2008 - 06:39:50 PM »
Curious to see what the shortblock i have is worth.
*Its a Mopar Performance 360 + .020 shortblock w/pan. Apparently ~3,000miles on it when purchased.
       The 10:1 version. Hyper pistons, cast crank, forged rods. Currently with the 'stock' .509 cam that comes with it. Right angle oil filter
       adapter. Windage tray w/studs. This is the magnum version so LA or Magnum heads can be run on it.
*Brand new roller lifters, factory spider/dog bones setup, so it can be run as a roller cam. (or flat tappet)
*Set of new ARP Magnum Edelbrock Head Bolts
*Edelbrock Magnum AirGap intake manifold, has one heli-coil on the carb mounting bolts.
*Stock 998 transmission (HD 904 basically), don't recall if it is the low-gear 1/2 version or not off hand.
All this stuff is in storage back in Vegas, considering I may rather play with a 5.7L Hemi when I get around to another mill.
Thanks!  :2thumbs:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline matt63
Re: Curious WIW MP 360 Shortblock + Goodies
« Reply #1 on: April 20, 2008 - 08:18:33 PM »
Mancini sells the short block for $1775.00 if that helps.
Matt in Edmonton
'68 Valiant
« Reply #2 on: April 21, 2008 - 12:28:03 PM »
Thanks, Bump?
1976 Dodge Warlock
