Author Topic: Back-up Light stays on  (Read 1533 times)
Offline VTMopar
« on: April 22, 2008 - 11:01:38 PM »
My back-up light on my '70 challenger works (properly) in reverse; goes out in neutral/park -- but unfortunately comes on when going forward......
Any suggestions on what may be causing this....??
Thanks
Vermont MOPAR
VT MOPAR
Offline VTMopar
Re: Back-up Light stays on
« Reply #1 on: April 24, 2008 - 09:27:48 PM »
Did I stump you guys?     :clueless:
Vermont MOPAR
VT MOPAR
« Reply #2 on: April 24, 2008 - 09:33:52 PM »
I was leaving this for someone with experience like Terry.... There have been several posts on the subject you might do a search but it seems like the switch can be too far in or not far enough in, there is some adjustment that can be made to the shifter I think...& of course the hardware in the tranny that pushes on the switch can have issues.
Wade
Offline VTMopar
« Reply #3 on: April 24, 2008 - 10:41:13 PM »
Good ideas..... didn't think of the shifter linkage --  Sounds like a good weekend project!   thanks!
Vermont MOPAR
VT MOPAR
Offline DAYLEY/CHALLENGER
« Reply #4 on: April 24, 2008 - 10:56:14 PM »
I have the same thing.  I just took out the light until I have time to correct.  I started to put a spacer in the switch on afternoon but I didn't have the car slanted enough and fluid started out.  Later I said.  I don't drive much at night anyway!! :bigsmile:  at least not in the Challenger.
Dave or David
« Reply #5 on: April 25, 2008 - 02:25:17 AM »
it could be the wrong Comb inside the tranny on the valve body but I doubt it , as suggested above you may need a double gasket to move the switch out a bit
Offline VTMopar
« Reply #6 on: April 25, 2008 - 07:26:11 PM »
Great minds think alike -- I had already taken the light bulbs out -- but still would like to get it "fixed" at some point.   Thanks for the advice!
Vermont MOPAR
VT MOPAR
