Author Topic: Tranplant a 426 or 440 in a 1974 318?  (Read 1608 times)
Offline cdvana
  • Newbie
« on: April 23, 2008 - 02:22:26 PM »
Hi,
I'm thinking of kicking out the 318 in my 1974 Challenger and dropping in a 440 or 426.  Could this be done?  What issues would come up?  Obviously I would need a new transmission.  Would there be any issues making it a manual?   I know this is open ended, but just looking for verification that it can be done.  Thanks
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Tranplant a 426 or 440 in a 1974 318?
« Reply #1 on: April 23, 2008 - 02:26:17 PM »
It's a relatively easy process. I've done it a couple of times. There is a list of parts that need to be swapped like the radiator, because the inlet and outlets are on opposites side for big block and small block.
1996 Dodge Viper GTS Coupe
Offline Challenger6pak
« Reply #2 on: April 23, 2008 - 09:51:31 PM »
I would consider how much you plan to use the car also.  With gas prices climbing toward the $5 a gal. mark I am reconsidering what motor to put into what car based on how much I am going to use it.
« Reply #3 on: April 24, 2008 - 02:54:35 AM »
no issues , either can be bolted into place , you need to upgrade a lot of parts diff if it is not an 8 3/4 , driveshaft to large joints , either 727 or 833 is a bolt in , GV OD is bolt in as well , Torsion bars , Rad will need to be upgraded , mounts brackets etc all will be different , virtually all parts are available
Offline Aussie Challenger
« Reply #4 on: April 25, 2008 - 08:23:29 AM »
  A very good upgrade, you just need to make sure you have the folding stuff, if a manual is to be installed you will need to change the floor/hump. The good thing is everything is available, ask what you will somebody will have done it before and should be able to steer you on the correct path.   :2thumbs:
Offline hemiken
« Reply #5 on: April 25, 2008 - 08:35:59 AM »
 :iagree: with AC........... :2thumbs:
Great choices. :clapping:
Offline 73Chally
« Reply #6 on: April 25, 2008 - 08:43:02 AM »
Both the Hemo and 440 will require a lot of new parts over the small block, but a major difference between those 2 is that the 440 will use the original K-frame in your car, but you will either need a correct Hemi K-frame, or modify your existing one, if you go that route.  Also, when deciding between the 2, keep in mind the streetability of the car.  A Hemi is great, but can give you headaches with tuning, especially if multi-carbed, and is built for high RPM running.  The 440 is a much better street motor.  You pretty much drop it in and go.  Either way, you will be much happier.  :2thumbs:
« Reply #7 on: April 25, 2008 - 01:17:56 PM »
the Hemi bolts in with Schumaker mounts on the K frame you have with no mods
Offline 73Chally
« Reply #8 on: April 25, 2008 - 01:52:03 PM »
Cool.  I didn't know that.  Thanks.  :2thumbs:
