Author Topic: 904 & 727  (Read 4865 times)
lemonboy69
904 & 727
« on: March 04, 2004 - 02:41:48 PM »
CP... or anyone else that might know... I was talking with my trans instructor today about old Chrysler transmissions... he says that the 904 only came in a 3 speeds (I partly agree with that, but thought they also came with 4 speeds)... then he also said that the 727 was just a stronger version of the 904 (which is true), but he said that the 727 was also only a 3 speed (which I don't agree with)...???  ??? ???
He said Chrysler didn't come out with 4 speed transmissions until the mid-80's and it was a 604 or a 606 trans.... ::) ???
I'm really confused here and need some help clearing this up!!
Thanks guys!!
LB
Offline budrinker
Re:904 & 727
« Reply #1 on: March 04, 2004 - 03:08:45 PM »
i think he is correct
L1
L2
drive
= 3 SPEED
lemonboy69
Re:904 & 727
« Reply #2 on: March 04, 2004 - 03:30:09 PM »
Hmmm... I always thought that there was an O/D or 4th gear on the 727's....??
Thanks budrinker!
LB
Offline Carlwalski
Re:904 & 727
« Reply #3 on: March 04, 2004 - 08:29:28 PM »
My 727 is a 3-speed, most of them are unles they get a O/D installed. 904 4-speed, I myself have not heard of a stock 904 with this option. A518 etc would have them but not the early  70's and prior models. You thinking of changing to a 727?  :D
« Last Edit: March 04, 2004 - 08:30:14 PM by NZ 440RT »
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Re:904 & 727
« Reply #4 on: March 04, 2004 - 10:55:30 PM »
H eis correct , the 727 & 904 were only 3 spds
 the newer 518 & Cummins autos are supposed to be based on the 727 but are not designated as 727 trannies
« Last Edit: March 05, 2004 - 10:24:08 AM by Chryco Psycho »
lemonboy69
Re:904 & 727
« Reply #5 on: March 04, 2004 - 11:24:19 PM »
Glad I didn't put any money down on this... I'll see him Tuesday... have to tell him he's right... he'll just say, "I told ya so!"... ::) :'(
Thanks guys!!
Oh, NZ... no 727... just a NICE B&M shift kit in the 904!! ;)
LB
Offline Carlwalski
Re:904 & 727
« Reply #6 on: March 04, 2004 - 11:45:43 PM »
Cool Mike, That will have no problem handling the /6 beast!  :D
Floor shift with OEM aftermarket Market shifter OR keeping the column shift?  ;D Have you thought TCI kits?  ???
Offline DodgeFreak
  • Cars and trucks are my friends..
Re:904 & 727
« Reply #7 on: March 04, 2004 - 11:49:53 PM »
the 518s aren't anywhere near as strong as the good ol 727s.......but they work most of the time..... ;D enless you get the 518 built it won't stand up to the power the 727s did..
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
lemonboy69
Re:904 & 727
« Reply #8 on: March 05, 2004 - 01:16:49 AM »
NZ.. TCI shift kits have started giving Mopars problems... I'll stick with his recommendation and get a B&M!! Oh, good old column shift too!!
 ;) ;) :D
LB
Offline Carlwalski
Re:904 & 727
« Reply #9 on: March 05, 2004 - 02:09:12 AM »
IMO TCI is the best, but B&M shift kits aren't bad. They both use a lot of the same insides.  ;D
Yeah!!!! Column shift sleeper!!  8)
Offline 1973challenger360
Re:904 & 727
« Reply #10 on: March 05, 2004 - 03:10:39 AM »
518's suck and some other newer trannys
my buddy Indy Ram died at 85,000
his dads 98 cummins less than that
my uncles 94 V-10 died
the neighbors ram 1500 died last year
and a few other friends with other trucks
dakotas, jeeps and rams
I hope these Benz 5spd autos work better
Offline Pistol Gripper
Re:904 & 727
« Reply #11 on: March 05, 2004 - 04:28:16 AM »
LB,
It's a good thing that your instructor gets to say " I told you so"  What would you be learning if he didn't know the difference ?  ;)
If you find any problems with the 904, I have a 727 here that came off a 360 from a Van, should be heavy duty.
P.G.
O ne
B ig
A $$
M istake
A merica
lemonboy69
Re:904 & 727
« Reply #12 on: March 05, 2004 - 10:00:09 AM »
Thanks PG... but I'll put some money on that 727.... the bellhousing will be bigger then my 904... especially if it came out of a van.... ::)
Now, another question so I don't feel like a dumbass... the 727's that were on the 440's and Hemi's had larger bellhousings then those on a small block say... but were the small block housings bigger then a slant six housing?? ??? ???
LB
Re:904 & 727
« Reply #13 on: March 05, 2004 - 10:27:55 AM »
the big blocks , small blocks & slant use 3 different belhousings
 A big part of the problem with new trannys is that people now want smooth shifts even with the huge torque of the Cummins , this wears the tranny out much faster than a hard shift will , the Best thing to do with a new car or truck is make it shift harder
lemonboy69
Re:904 & 727
« Reply #14 on: March 05, 2004 - 10:39:24 AM »
Alrighty... that clears most everything up now!!! ;D ;D Looks like it's the shift kit with my stock 904!! One last question, I promise CP!! :P Did they ever make a 727 that would fit the /6?? ::)
LB
