Author Topic: What are you doing with your ebody this weekend?  (Read 591506 times)
Offline wally426ci
    • maryland mopars
Re: What are you doing with your ebody this weekend?
« Reply #1245 on: March 06, 2010 - 04:33:31 PM »
I finallly oredered the parts to fix my leaking 727 dipstick tube. I'll be changing the oil, and rejetting the carb and  :burnout: hopefully.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline CHL2T
  • Handle it, man!
« Reply #1246 on: March 06, 2010 - 05:05:30 PM »
This is what I've done this morning
Put 74 rallyes on Cuda, Drives so much better than the 25 year old rotten flat spotted POS I pulled off, and looks better too!
New 15's on Challenger, I need to outline the letters on the Challenger, Otherwise, perfection
Offline CHL2T
  • Handle it, man!
« Reply #1247 on: March 06, 2010 - 07:21:20 PM »
Just got through doing the alternator to starter relay rewire thing, re-did the terminals at the alternator, and tightened the voltage regulator, now the volts are rock solid and no more headlight flicker :2thumbs:
Still need to get the ammeter out of the loop, but that can wait
Offline BIGSHCLUNK
« Reply #1248 on: March 06, 2010 - 07:25:11 PM »
I'm really gonna make an effort to get out to the garage tomorrow!! Supposed to be mid-40's here (ya heat wave LOL) Maybe get my wiper motor out, looks like the roads still have to much salt here to go for a ride but it will be good just to get started on a few things!  :working:  :2thumbs:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline moparclown
« Reply #1249 on: March 06, 2010 - 09:07:07 PM »
Weather was sweeeeet today here,almost 50 degrees.Fired up the 69 Cuda pulled it outside,cleaned the garage out and rolled the Daytona Iroc R/T into the garage.I pulled the turbo out and the new one is in(what a serious pain in the butt)My body aches bad from working like a wild man,but couldn't be happier :roflsmiley:I welcome Spring with open arms :cheers:
Offline rallye5.7
« Reply #1250 on: March 13, 2010 - 05:53:00 PM »
Finally got back to work on it today after almost two months off and brought in some professional help to guide me through a few areas. Got the trans linkages hooked up, finished the trany lines and filler tube. Modified the bell housing cover and installed the starter. The fuel system is in place and wired.Most of the underhood wiring is complete. Tomorrow drive shaft and speedo cable and reinstall the headers. We'll also try to finish mounting the computer and re&re the dash one more time.
Had a few beers time to call it a day :working:................. :cheers:
Offline CHL2T
  • Handle it, man!
« Reply #1251 on: March 13, 2010 - 06:03:33 PM »
Driving them :2thumbs:
« Reply #1252 on: March 13, 2010 - 06:08:12 PM »
Well, Im stuck on the road working, but I did get over to the Indy swap meet and purchase some billet aluminum jet plates for the outboard carbs on my 6pk to re jet it for better performance.  Promax makes these plates
« Reply #1253 on: March 13, 2010 - 09:41:04 PM »
Installed new carpet, bolted my new "tuff wheel" together,finish welded my subframe conectors,  ran light bulb harness to slap stick shift light indicator , and  painted some of the undercarrage.
Offline rtgambit
  • Member since March 31, 2003
« Reply #1254 on: March 13, 2010 - 10:17:58 PM »
Gonna do some trunk lip welding on Sunday. I don't think I'll have time for much else (missus made other plans for the afternoon).  :stomp:
Matthew
1967 Dodge Dart GT
1971 Dodge Challenger R/T
2014 Ram 1500
Offline thenuke1
« Reply #1255 on: March 14, 2010 - 01:12:55 AM »
i FINALLY have a weekend day off which is tomorrow ... BUT i got a medical term test on monday so i might study for a bit and take her out for a wash and cruise to get lunch or something ... then come back home and study some more
(OO{+++++++}I{+++DODGE}OO)
     o                               o
71 Challenger
If its got BOOBS or an ENGINE, your gonna have problems.
Offline GoodysGotaCuda
« Reply #1256 on: March 15, 2010 - 11:40:29 PM »
I brought it home out of storage for a little bit. Put some miles on it, tweak the carb some. I replaced the driver's side header gasket that was leaking. Isolated my blue pump better so it's not teeth chattering loud anymore, and fixed my trans mount issue.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #1257 on: March 16, 2010 - 12:06:47 AM »
I stripped the passenger door and fender today then primered them.
I'm estimating now that it might be about gallon and a half of primer to completely epoxy primer the whole car.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #1258 on: March 16, 2010 - 07:17:46 PM »
If the weather holds off I'm going to move it from my rental garage to my new(to me) house garage.  I had it running today after charging the battery, fired up without much fanfare, but the stink was unreal.  Made my eyes burn but my smile was :bigsmile:
Tom
Tom
« Reply #1259 on: March 16, 2010 - 08:46:59 PM »
Finished seam welding the rear frame rails, POR15 and seam sealer. Under coat next. Next, I need to go over Shelbydogg's rear axle post in the archives. If you haven't seen it, it's a good how-to for 8-3/4" rears.
