What are you doing with your ebody this weekend?
Author Topic: What are you doing with your ebody this weekend?  (Read 591456 times)
Offline thenuke1
Re: What are you doing with your ebody this weekend?
« Reply #1335 on: April 23, 2010 - 11:56:27 AM »
not sure yet ... im still on the fence about Burbank Kiwanis this Sunday. We'll see
(OO{+++++++}I{+++DODGE}OO)
     o                               o
71 Challenger
If its got BOOBS or an ENGINE, your gonna have problems.
sleepychallenger
« Reply #1336 on: April 23, 2010 - 02:22:29 PM »
stripping the chrome off the car now....almost ready to sand and prime
Offline RB2929
« Reply #1337 on: April 23, 2010 - 11:02:19 PM »
Finally have a weekend w/o snow, rain, or tornadoes. :bananasmi
Saturday, giving the Rumble Bee a long over do inside/outside wash.
Sunday, cruising the Cuda
The Moog front end rebuild kit arrived.  Figure that it will take longer than a weekend to install. So, enjoying the car before she's on jacks for a month or two. :faint:
Offline BIGSHCLUNK
« Reply #1338 on: April 23, 2010 - 11:58:53 PM »
Stering gear should be out tomorrow....  providing I can get the exhaust man out w/o to much hassle..  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #1339 on: April 24, 2010 - 03:04:23 AM »
I have a million little things things to do this weekend.  I need to make and install a gas tank filler tube to body gasket so my trim ring fits snugly.  Then replace the filler tube to tank seal.  Also I need to clean out the trunk and look into fixing a cracked filler tube trunk seal.  Then paint the flip top gas cap base black.  Under the car I need to fix up my kickdown linkage and install the spring up by the carb.  Up front I need to put on the new lug nuts and unilug spacers for my Keystone Klassics.    After all that I need to install the drivers side front turn signal lens, and paint the rear spoiler.  While the pain is in the gun I'll paint the grille black ala R/T after I polish the shiny bits.  If I have time I need to repaint the black on my rims.  Then....  take apart and inspect my remote mirror to see if I can get it to work.  Then I'll do the tighten up on the pass side mirror so it stays in place.  I also need to install my Grans Spaulding Dodge lic plate frame and Scat Pack decals in the qtr windows.  If I have the time I'll check out the leak by the trans, and install a shift kit and change the trans fluid.  Also add a qt of oil while the hood is up.  While I am down by the lic plate I need to install the right hardware for my rear valence.  It's loose on one end and fitting poorly.
I hope I can get some of that stuff done this weekend.  I'll need to get a MC ride in as well.  It's supposed to be nice at the beach and that means the bikinis will be out in force.   :cooldancing:
Offline quapman
    • Auto-Grip on Facebook
« Reply #1340 on: April 24, 2010 - 11:58:09 AM »
Well, this morning I got my new heater core for the 73, took some parts off the S.E., removed the windshield and dash assembly out of the 70 R/T (so nobody steals the VIN tag or speaker grilles) and tried to decide how to juggle all the wheels I want to keep/not keep on the cars I'll be selling.
If it doesn't rain, I'll be bleeding brakes and installing an antenna on the 73.
Front valance and parking lights went in last week.
Offline Challenger III
« Reply #1341 on: April 24, 2010 - 12:25:15 PM »
Moving it to the shop for the summer.
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline moparclown
« Reply #1342 on: April 24, 2010 - 09:26:35 PM »
Last year at this time(1st pic)
As of today(2nd pic)
sleepychallenger
« Reply #1343 on: April 24, 2010 - 11:05:49 PM »
after who knows how long of having a duchman panel that I got from clown, i finally found a use for it. we replace a good section of the rear winshield channel from the extra area that he included. Thank you so much clown, you really saved my butt.
now i just have three pin head sized holes from under the vinyl top to fix and all the metal work on my car is done!!!
« Reply #1344 on: April 24, 2010 - 11:40:54 PM »
Pulled the small dent out at the drivers mirror using stud gun.
Fabbed quarter panel corner to match up correctly to the top of door.
Goodmark...ya know! Alot of grinding and welding to get these just right.
Aligned door lines to quarter panel. then tried to get fender aligned to door. Called it a day. OMG this alignment work is brutal.
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #1345 on: April 25, 2010 - 07:18:42 PM »
Took the 'cuda on her first car show of the season with two Norwegian friends from this forum
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline 41husk
« Reply #1346 on: April 25, 2010 - 07:28:24 PM »
Rain through the weekend ending Tuesday.  I guess I will be looking at it in the garage.
1969 Dodge Charger Daytona Clone 440/727
1970 Dodge Challenger Convertible 340/727
1977 Dodge D-700 Car Hauler 361/5spd
2009 Dodge Challenger SRT8 6.1/auto
Offline thenuke1
« Reply #1347 on: April 25, 2010 - 08:04:43 PM »
well no burbank show BUT the weekend wasn't a waste ...
bought these at spring fling 2010 & 2009
and today i decided to put them on the car after some painting ... they need to be finished but ill do that when they dry ... both of them were broken but for $5 and $3 bucks a piece ill get by specially when they go from 40-75 on ebay...
i also got a bit creative with my blackberry... lol
     o                               o
71 Challenger
Offline 41husk
« Reply #1348 on: April 25, 2010 - 08:20:13 PM »
Cool a plumb crazy R/t Blackberry.  What you got in it?
Offline 422STROKER
  • Member Since 6/3/06
« Reply #1349 on: April 25, 2010 - 09:17:44 PM »
Nothing but a sponge bath and putting miles on it. :icon16:
Tom :bigshades:
Tom
