Author Topic: What are you doing with your ebody this weekend?  (Read 591411 times)
Re: What are you doing with your ebody this weekend?
« Reply #1515 on: September 14, 2010 - 10:50:55 PM »
Drove the 72 shaker cuda around today. found an old junk yard. Ended up buying 2 rust free doors for my dodge truck for 70 bucks complete. bought a heavy duty chrome rear bumper for 25 bucks and a reese trailer hitch off the truck for 25 bucks. The paint on the doors was the same color as mine :2thumbs: Also found a 62 dart, 71 dart, and a 68 1 ton dodge truck.  It was a good day
Offline acudanut
« Reply #1516 on: September 14, 2010 - 11:40:35 PM »
  Mine is still sleeping. zzzzzzzzzz
Offline Aloid
  • Simi Valley, CA
« Reply #1517 on: September 15, 2010 - 02:00:46 AM »
Took some pictures...
          going to install a new balanced t-stat and shroud...
                       then work on a tranny leak (at the dip stick tube connection)...
                                   then windows...
                                                 endless... but fun!
'73    (O[   ]||||[   ]O)
////  NAME CHANGED TO 360FISH  \\\\
Offline mopar12372
    • mopartech
« Reply #1518 on: September 17, 2010 - 12:59:53 AM »
nice ride al !! wow ,i like your verson of endless --> the car makes noise hahahaha
RESTO PICTURES
« Reply #1519 on: September 17, 2010 - 01:22:36 AM »
Where do you get them at?
Offline Aloid
  • Simi Valley, CA
« Reply #1520 on: September 17, 2010 - 02:59:31 AM »
Mr. Gasket 180* T-stat #4367 from JEGS...  Chrome shroud from Amazon (Trans Dapt #9454) it looks good, is cheap & free shipping.  It's not a full shroud, but should still help direct airflow.   Will post a pic this weekend.
Thanks Bill!  You'll get your beast on the road someday.  I'll be there to buy you a congratulations beer!
Alan
« Last Edit: September 17, 2010 - 03:06:10 AM by Aloid »
'73    (O[   ]||||[   ]O)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #1521 on: September 18, 2010 - 04:48:52 AM »
I have a million little things things to do this weekend.  I need to make and install a gas tank filler tube to body gasket so my trim ring fits snugly.  Then replace the filler tube to tank seal.  Also I need to clean out the trunk and look into fixing a cracked filler tube trunk seal.  Then paint the flip top gas cap base black.  Under the car I need to fix up my kickdown linkage and install the spring up by the carb.  Up front I need to put on the new lug nuts and unilug spacers for my Keystone Klassics.    After all that I need to install the drivers side front turn signal lens, and paint the rear spoiler.  While the pain is in the gun I'll paint the grille black ala R/T after I polish the shiny bits.  If I have time I need to repaint the black on my rims.  Then....  take apart and inspect my remote mirror to see if I can get it to work.  Then I'll do the tighten up on the pass side mirror so it stays in place.  I also need to install my Grans Spaulding Dodge lic plate frame and Scat Pack decals in the qtr windows.  If I have the time I'll check out the leak by the trans, and install a shift kit and change the trans fluid.  Also add a qt of oil while the hood is up.  While I am down by the lic plate I need to install the right hardware for my rear valence.  It's loose on one end and fitting poorly.
I hope I can get some of that stuff done this weekend.  I'll need to get a MC ride in as well.  It's supposed to be nice at the beach and that means the bikinis will be out in force.   :cooldancing:
I am still working on a few of these things from April.   :popcorn:
Offline miketyler
    • www.miketyler.net
« Reply #1522 on: September 18, 2010 - 10:24:22 AM »
putting in LED tails, reverse lights and front running lights/turn signals
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline 67vertman
  • Member since 9-23-2005
« Reply #1523 on: September 18, 2010 - 02:39:28 PM »
All I get to do is start her and warm it up.  I don't even have time to take her for a drive.  :hyper:
I am too busy working!  except for this short break/CC.Com fix.  :swaying:
Offline T-bar
« Reply #1524 on: September 18, 2010 - 05:34:53 PM »
I'm gonna put the interior back together after an engineer inspected the new mouting points for the front and rear seatbelts (crazy Australian law). Then set the valve lash as a bit of general maintanence. Then hopefully sometime this week we'll be off to get a roadworthy cert. (another Aussie road law) to get it registed and plated and then on the road for some cruise time. :woo: :bananasmi :cooldancing:
Offline GoodysGotaCuda
« Reply #1525 on: September 18, 2010 - 06:15:57 PM »
I drove it around to the several community garage sales this morning, then proceeded to drive it like it stole it home!  :2thumbs:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
« Reply #1526 on: September 18, 2010 - 08:32:26 PM »
Went to a car show today. Going to one tomorrow with a bunch of other muscle cars.  :burnout:
« Reply #1527 on: September 19, 2010 - 10:08:44 AM »
Went to a local county fair. Got in free as I entered the car show! My Dad brought his hot rod too, so we got to spend some time together!
« Reply #1528 on: September 19, 2010 - 11:58:23 AM »
Got some "earl" and changed the "earl" in it. Had to clean up the drool from the guys at the parts store though  :bigsmile: :wavingflag:
1976 Dodge Warlock
Offline autoxcuda
    • Spring Fling
« Reply #1529 on: September 19, 2010 - 12:16:25 PM »
                                   then windows...
                                                 endless... but fun!
Maybe I'll see it cruising around Simi Valley. Are you going to the next Chuy's Cruise In on L.A. ave on October 2, 2010 : http://www.flickr.com/photos/20988369@N07/sets/72157624788294167/   http://otas-usa.com/chuys-cruise-night-simi-valley-ca
You are going to bring your Cuda to Fall Fling right?
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
