What are you doing with your ebody this weekend?
Author Topic: What are you doing with your ebody this weekend?  (Read 590977 times)
Offline 67vertman
  • Member since 9-23-2005
Re: What are you doing with your ebody this weekend?
« Reply #2160 on: January 01, 2013 - 10:29:41 PM »
Spent the day putting in my Griffith Radiator and new Flex Cool hose’s in my car.  Both are great quality and craftsmanship.  The radiator took some minor modifications to get the stock fan shroud on, but other than that bolted right on.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2161 on: January 02, 2013 - 01:17:43 PM »
Hey Vertman
Can you let me know why you went with a clutchfan and what kind of pulleys are those. I'm kinda considering going stock or maybe some nice new aluminum ones.
Thanks,
Bryan
Offline 67vertman
« Reply #2162 on: January 02, 2013 - 08:34:05 PM »
Hey Vertman
Thanks,
Bryan
Hi Bryan,
I choose to go with the clutchfan as I didn’t want to run electric fans (for now), and to keep the stock look.  If the stock system works and keeps my motor cool, then I will continue to run the fan clutch, if not I will then go with electric fan(s).
I am running the March pulley setup, as I didn’t want the hassle, with piecing together all the pulleys for my setup, plus I wanted the serpentine belt look.  It cost a little more, but was pretty much a bolt in system, I only had to do two minor modifications to make the system work with the aluminum heads.
« Reply #2163 on: January 02, 2013 - 08:39:36 PM »
Hi Bryan,
sweet looking bullet! :cooldancing: :2thumbs:
Offline 67vertman
« Reply #2164 on: January 02, 2013 - 08:48:15 PM »
Thanks Brad, it looks even better in the car.  :woohoo:
Offline dutch
« Reply #2165 on: January 03, 2013 - 04:09:32 AM »
 :drool:
*** Bart ***
« Reply #2166 on: January 03, 2013 - 04:26:18 PM »
It sure does!  :2thumbs: :clapping:
« Reply #2167 on: January 03, 2013 - 04:35:26 PM »
It would look even better if I had it over here with me :smilielol:
I just finished converting CudaGuys car over to standard disc brakes.  Now for plug wire insulators, re set the valves and then rip out his under the dash a/c system. nHe is so close to taking it home, if he ever leaves Hawai :faint:
Offline GranCuda1970
« Reply #2168 on: January 05, 2013 - 12:21:54 PM »
Time to drive !!  :burnout:  :ylsuper:
Offline dutch
« Reply #2169 on: January 05, 2013 - 01:07:06 PM »
finally installing my windshield tonight  :bananasmi
*** Bart ***
« Reply #2170 on: January 05, 2013 - 02:35:05 PM »
 :bananasmi :clapping: :2thumbs:
Offline 1970A66D21
  • Livin in Vegas
« Reply #2171 on: January 05, 2013 - 03:56:11 PM »
I will be installing my grill so my body/paint guy can get the correct contour on the drivers side front fender instead of guessing at it like he did the first time.I have not been able to install the headlight bezel.
Taking the car to the muffler shop next Thursday and the painters next Sunday.
Offline 67vertman
« Reply #2172 on: January 05, 2013 - 04:44:15 PM »
 :woo:
Very close to driving it. I got it started and running, for the first time with the new motor in it.   :bananasmi  :ylsuper:  :clapping:
Man she sounds bad a$$,  :bigsmile:
« Reply #2173 on: January 05, 2013 - 04:50:16 PM »
 :jumping:   :clapping:  :hyper: Can you make a vid!  :drool: :drool: I wanna hear too!!  :ylsuper:
Offline 67vertman
« Reply #2174 on: January 05, 2013 - 08:18:29 PM »
Yeah I need to do that.
