Author Topic: What are you doing with your ebody this weekend?  (Read 591061 times)
Offline ntstlgl1970
  • T a c o c a t
Re: What are you doing with your ebody this weekend?
« Reply #2460 on: March 15, 2014 - 02:51:44 AM »
Wiring up and putting new windshield back in car with correct 3/8's butyl tape!
 :bricks1:
can you get thicker tape? I think 3/8ths is too thin unless you have the thicker factory windshield. I used 3/8ths with a replacement windshield and it makes all the trim sit too low - of course I could have put it in wrong too - I'm good at that kind of stuff..
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2461 on: March 15, 2014 - 01:30:00 PM »
The kicker is that when you set the windshield on the 3/8" butyl tape you DON'T press down on the window squishing the sealer.
3/8" butyl tape is the correct size and you need to have someone who really knows their cars.
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #2462 on: March 15, 2014 - 06:17:29 PM »
Re-installed my alternator after having two places tell me it was bad and two places said it was fine.  the last place I took it too was an automotive electrical rebuild shop, and said they would have it fixed by the end of the day yesterday.  they called me about an hour after I dropped it off and said it was fine.  I figured I could trust these guys!  I bought a regulator from them, as that would be the next culprit for a Discharging Ammeter.  sure enough, put on the new regulator too, fired her up, and the Ammeter was showing Charge!  woooo!   :woohoo: :woohoo:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2463 on: March 15, 2014 - 08:09:43 PM »
Replacing the rusted out trunk floor in my '71 Chally!
Offline Sleepychallenger
« Reply #2464 on: March 16, 2014 - 10:18:14 AM »
 :2thumbs: looks like fun there dfrazz
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #2465 on: March 16, 2014 - 02:09:37 PM »
Cleaned, masked, painted and test fitting...
First time building a front suspension. A lot of thanks to all of you that have posted yours! So if you see anything bass ackwards feel free to say so. BTW the Pitman arm is not all the way on because it needs to be indexed. Just not sure yet how to do that. And the Tie rod ends could be inside out but I think I got them right.
Caliper paint for the calipers, Cast Blast on all the natural looking parts, Cast Blast High Heat on the other brake parts and Rust-olem Satin Nickel Lower Control Arms.
Not going for factory correct colors, I just looked at what others had done and did them the way I thought looked good.
Decided to paint instead of PC to save a few buck$$.
Not sure if I should paint the dust shields gloss black or keep them natural.
What do you guys like them to be? :feedback:
Still a long way to go. I think I'll have to beef up my dolly before I put any more parts on.
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2466 on: March 16, 2014 - 07:37:09 PM »
Yet another windshield is in but correctly this time.
Moving fast now.   :clapping:
Offline ToxicWolf
« Reply #2467 on: March 16, 2014 - 09:06:32 PM »
That's what happens when summer gets close.  Go get 'em!   :clapping:
« Reply #2468 on: March 16, 2014 - 09:24:35 PM »
Looks great! Is that the fast ratio arms on the new Boregson box?
Offline Cudaragtop
« Reply #2469 on: March 16, 2014 - 11:33:15 PM »
Quote
Yes it is, I went with the fast ratio Pitman and Idler arms from PST.
- Randy D.
Offline Cudaragtop
« Reply #2470 on: March 16, 2014 - 11:37:25 PM »
 :working:
Went back out and added the Hellwig FSB.
- Randy D.
« Reply #2471 on: March 17, 2014 - 06:38:42 AM »
:clapping: can't wait to hear what its like, especially  at hwy speeds. :2thumbs: I'm considering the new box too at some point?
Offline Joe mama
« Reply #2472 on: March 17, 2014 - 04:52:09 PM »
Started the car for the first time with the 6 pack installed. Sounds great! Can't wait for the roads to dry from all the melting snow so I can try it out. Ordered a March serpintine belt system and vintage air.
73 Challenger, 440+6, 5 speed Tremec, Dana 60
Offline Cudaragtop
« Reply #2473 on: March 17, 2014 - 09:15:14 PM »
Nice :thumbsup:
Are you replacing an existing AC system or adding AC to a Non-AC car?
I've wondered if there was a clean way to add AC to my Non-AC car...
Look forward to seeing how that goes.
- Randy D.
Offline Joe mama
« Reply #2474 on: March 18, 2014 - 04:33:12 PM »
I'm adding A/C to a non A/C car. I'll add pictures once I start the install.
