Author Topic: What are you doing with your ebody this weekend?  (Read 591130 times)
Offline GreenFishie
Re: What are you doing with your ebody this weekend?
« Reply #2535 on: April 25, 2014 - 04:26:39 AM »
Crossing my fingers here, but if it doesn't get too wet I'll be able to finish planting by Friday afternoon and be able to spend the up until mid-day Sunday removing the front clip and grinding away on the uni prepping it for the flat bed to take it away to CU ... where I can spend a few hours during the week working on it at a colleague's better equipped garage (it has heat, AC ... and ventilation ... to be tenured and loaded).
The front clip is trash. It isn't stock and the replacement looks like it was made from several rolls of tinfoil. I'm wondering if there are some good after-market subs out there that would just let me completely modernize the front suspension.
Offline blown motor
« Reply #2536 on: April 25, 2014 - 08:21:16 AM »
Greenfishie, where are you located? Zero tillage or planting done here in my part of Ontario. Nitrogen started going on the wheat yesterday. Last year a lot of corn was in by now.
Offline 67vertman
  • Member since 9-23-2005
« Reply #2537 on: April 27, 2014 - 06:28:04 PM »
I took mine out for a drive today and bought some 110 Octane racing gas.  It sure woke up the engine!  I I am only running 10:1 compression so I was quite surprised at the difference in feel.
While I was out the battery decide to quite on me.   :swear:  :clueless: No worrning or anything, pulled up to the stop light and she died....then the dreaded click click click.  Luckly someone held traffic while I rolled it over to the curb.
Had to get a new battery, but I made it home once I put the new one in.  :bananasmi
« Reply #2538 on: April 27, 2014 - 07:18:21 PM »
Battery is just for starting sounds like a charging issue to me?
Offline 67vertman
« Reply #2539 on: April 27, 2014 - 11:22:25 PM »
I agree Brad.  But with the EFI and computer it takes a lot of volts/amp to keep the battery charged.  I need to check and see if the Alt is putting out enough voltage.
Offline 67vertman
« Reply #2540 on: April 28, 2014 - 09:19:41 PM »
Brad, I got a chance to test the altinator tonight.... :walkaway: its only putting out 11.56 volts.  :faint:
Time to order a new one.  Sad as this one is only two years old.  :swear:  :pullinghair:
« Reply #2541 on: April 28, 2014 - 09:22:19 PM »
I just bought a Powermaster from Year One. They're supposed to be top notch units.
Offline 67vertman
« Reply #2542 on: April 28, 2014 - 11:35:26 PM »
Thanks Mike.  I just ordered one from Summit Racing!  should be here by the weekend.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2543 on: April 29, 2014 - 12:21:39 AM »
Dropped the MSD pro billet distributor in!
 :cheers:
Offline Oldschool
  • Member Since 9-05-06
« Reply #2544 on: April 30, 2014 - 11:47:10 AM »
Transmission and torque converter flush Friday.....
Ken  --  In Georgia
Offline ToxicWolf
« Reply #2545 on: April 30, 2014 - 11:49:54 AM »
Lots of sanding on the exterior this weekend.   :woohoo:
Offline crash340
« Reply #2546 on: April 30, 2014 - 03:43:50 PM »
NOTHING!!! :stomp:
Its at home, desperatly wanting my attention and Im stuck out of town !!! I miss my Cuda  :working: :sadwavey:
Greg
73 Cuda
Brisbane, Australia
« Reply #2547 on: April 30, 2014 - 06:57:07 PM »
Most likely taking a plasma cutter to a brand new AMD fender.  :eek7:   :screwy:  :lol:
Offline anlauto
« Reply #2548 on: April 30, 2014 - 09:23:08 PM »
Wouldn't a die cutter give a cleaner cut ?
« Reply #2549 on: April 30, 2014 - 09:28:19 PM »
 :dunno: Do you think so?
