What are you doing with your ebody this weekend?
Author Topic: What are you doing with your ebody this weekend?  (Read 591174 times)
Offline 360FISH
  • BS23H3B567746
Re: What are you doing with your ebody this weekend?
« Reply #2595 on: May 17, 2014 - 01:48:59 PM »
Drove her into the office today......changed lives along the way!!!!  :bigsmile: :aussie: :burnout:
Mozz!!
 :clapping:
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2596 on: May 17, 2014 - 08:34:06 PM »
 Waiting for my new engine to arrive.....  :pullinghair: :banghead:
« Reply #2597 on: May 17, 2014 - 09:22:18 PM »
Engine runs better now with primary jets changed.
Brake lights now working.
Back at it tomorrow.
Timing, dist. not quite right yet.
Offline Sleepychallenger
« Reply #2598 on: May 17, 2014 - 10:33:48 PM »
 Whaccha gettin
« Reply #2599 on: May 18, 2014 - 08:22:25 AM »
Cut out the passenger side fender and today rolling out a new panel on the English wheel. The second side sure went much quicker than the first! :2thumbs:
Offline dfrazz
« Reply #2600 on: May 18, 2014 - 08:37:03 AM »
Whaccha gettin
408 Stroker from Carolina Machine Engines - awaiting its arrival
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #2601 on: May 18, 2014 - 12:16:45 PM »
Getting some parts ready to go back on the cuda.
Some before and after pictures
Trunk latch before
Trunk latch after
Hood Hook before
Hood hook after
Ready to be installed
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline spamtank
« Reply #2602 on: May 18, 2014 - 01:49:01 PM »
Changing the oil and greasing some fittings.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2603 on: May 18, 2014 - 02:52:48 PM »
Got my wiring harness!!!
 :working:
Offline crash340
« Reply #2604 on: May 18, 2014 - 04:17:37 PM »
Cudaragtop, what process did yo use on the trunk latch, hood catch etc, what finish did you apply after cleanup?
Greg
73 Cuda
Brisbane, Australia
Offline Cudaragtop
« Reply #2605 on: May 18, 2014 - 09:41:42 PM »
I soaked them in a mix of 50/50% muriatic acid and water.
Make sure you use eye protection and rubber gloves. Outside!
Read all the precautions! It's nasty stuff, you don't want to breathe the fumes either.
You should be able to get a gallon at your local hardware store for about $6 or $7 bucks.
Choose a container that your parts will fit easily. I used an empty plastic Costco cashew jar. Add your 50% water first then the acid.
I only used about 16 ounces, just enough to cover the parts.
I keep a small bucket with baking soda and water handy for neutralizing the acid on the parts when I take them out.
Light rust and oxidation will dissolve quickly. Be careful not to leave in too long or it will eat the good metal too!
Rinse well with fresh water. Then I dry them and blow them off with an air compressor. I wiped them down with acetone but you could use lacquer thinner too, then I sprayed them with VHT clear caliper paint.
I did an ashtray too and painted it SEM Landau Black.
If you do an ashtray don't leave the handle on it will dissolve... :scared:
- Randy D.
Offline Tonker1
« Reply #2606 on: May 19, 2014 - 08:55:03 AM »
Installing the pedal side of the hydraulic clutch and making a firewall reinforcement plate to stop the clutch piston bending the firewall out so much.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #2607 on: May 19, 2014 - 09:40:26 AM »
Moving it to my new house!  Finished the rustoleum epoxy on the floors and it's ready to be occupied by an ebody!
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline ec_co
« Reply #2608 on: May 19, 2014 - 04:08:19 PM »
cleaned out the garage the last 2 days to make room .... this weekend I'm heading up to WA to finally pick up my e-body! soon I'll be able to post real weekend progress :)
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
« Reply #2609 on: May 24, 2014 - 09:30:28 PM »
Good news:
Engine lifter noise is alot quiter now after re adjusting the valves again.
Adjusting solid lifters is something my friend Dave today showed me how to do the right way.
I had mine too loose by a few thousandths. This is harder to get "the right feel" than I imagined.
Also re jetted and meter rods put in. Adlusted to the .100 on the chart.
I cured the ignition yellow wire not connecting to relay. Now it starts by key. It was being intermittent.
Main issues left:
Engine dies out just under 1200 RPM. No indication of a vacuum leak. Guage read steady.
Wiper motor has no action. Ground or switch
Clock was working. Now it stopped.
Steering Federal pump doesn't seem to be assisting. I won't know for sure until I drive it.
Monday I make a decision to take to De Anza show or not.
I'm having idle problem now even after re jetting and upping the meter rods.
Stumbles just under 1300 rpms. No Vac leaks.
I think it's timimg left. I'm at 15 degrees before right now.
.585 lift, 250 dur.
