What are you doing with your ebody this weekend?
Author Topic: What are you doing with your ebody this weekend?  (Read 591221 times)
Offline 360FISH
  • BS23H3B567746
Re: What are you doing with your ebody this weekend?
« Reply #2670 on: July 28, 2014 - 03:44:14 PM »
Replaced my power brake booster…  reacquainted myself with a few cuss words I hadn’t used in a while and found myself wishing I could strangle the engineers who didn’t realize my fingers and arms don’t bend the way they designed things for that tight space.  ;)
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline dutch
« Reply #2671 on: July 28, 2014 - 05:07:05 PM »
lol!
.........is it working?  :biggrin:
*** Bart ***
Offline 360FISH
  • BS23H3B567746
« Reply #2672 on: July 29, 2014 - 04:24:24 PM »
Finally starting the "meat" of my 518 transmission install, getting my car up on the Kwik Lift and starting the process of removing the 727.
Awesome!  good luck with your conversion.  Keep us updated!
lol!
Yes!  thankfully...  though I had accidentally disconnected the switched power to the EFI unit while thrashing under the dash...  took a while to find...  and the old 8-pin harness connector to the steering column broke in my hand (repaired with electrical tape)... and the brake light switch was always on after the install...  adjusted the switch on the pedal...
It's like herding cats...  :)
Offline Ravage
  • 1974 318 'Cuda
« Reply #2673 on: August 01, 2014 - 02:26:42 PM »
Needle fell of my tach. a couple years ago. Finally replaced it. Looks neater but I need to get a better clamp. Any recommendations?
"I flipped off a box of kittens once..." (Tycho on being evil)
Offline blown motor
« Reply #2674 on: August 01, 2014 - 03:35:49 PM »
Rotate your clamp so the tightening screw is on the bottom. Then you won't see it. You could also paint the band black so it is less noticeable.
Offline Ravage
  • 1974 318 'Cuda
« Reply #2675 on: August 01, 2014 - 06:57:34 PM »
The clamp can't be helped. My 4" clamps are too small and my 6" are too big. Can't find 5", so I coupled a 4" and an old radiator clamp  ??? Band itself isn't too bad, just that old rusted one looks like crap and no matter how I turn it at least one worm gear will show.
Offline anlauto
« Reply #2676 on: August 01, 2014 - 08:01:57 PM »
Maybe a piece of two-way tape on the base and a black Zip-Tie :dunno:
Offline blown motor
« Reply #2677 on: August 02, 2014 - 09:04:07 AM »
Check with a farm equipment dealership for a 5" clamp. That's where I got mine.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2678 on: August 09, 2014 - 10:42:00 AM »
She's all dressed up for the Colorado Mopar Show today!
Offline anlauto
« Reply #2679 on: August 09, 2014 - 11:59:11 AM »
Nice car...You should add black R/T stripes and 71 side scoops :2cents:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2680 on: August 09, 2014 - 12:28:30 PM »
Brakes, brakes and more brakes!!!
Offline blown motor
« Reply #2681 on: August 09, 2014 - 12:38:04 PM »
Leaving it sit in the shed while I combine wheat. Soon done and then I can get back to  :burnout::woo:
Offline dutch
« Reply #2682 on: August 09, 2014 - 06:48:06 PM »
I did great things for the environment today. I drove a Hybrid. Burning gas and rubber  ::) My buddy had access to a Gopro cam through his employer so we took the cuda and taped about 45 minutes of musclecar cruizin in Dutch towns & countryside  :)  Plan was to use an external mic, so I made a bracket to hold it between the pipes,  but the input on the cam was toast....  :pullinghair:
It will still be fun to watch... when done...  :bigsmile:
He took a few pics as well. Here`s one
*** Bart ***
Offline hemiken
« Reply #2683 on: August 09, 2014 - 08:19:39 PM »
Nice shot Bart :bigshades: :ylsuper:
Offline dfrazz
« Reply #2684 on: August 09, 2014 - 08:26:59 PM »
I'm actually going to strip and re-paint it some other color in the next year or so because black is a pain in the a$$ to keep clean.
