Author Topic: What are you doing with your ebody this weekend?  (Read 591284 times)
Offline roadman5312
Re: What are you doing with your ebody this weekend?
« Reply #2775 on: January 30, 2015 - 07:17:09 AM »
Never had any luck with copper, always leaked. I now use Percys soft aluminum.
Offline Mopar Mitch
« Reply #2776 on: January 30, 2015 - 03:02:29 PM »
If the Fel-Pro's leaked exhaust, then you definitely have a problem that needs to be fixed... and copper is going the wrong direction.  The FP are conformable and forgiving; the copper are stiff and non-conformable/far less forgiving.  Check the flatness of the manifolds/headers, as well as the heads... and the bolt threading to be deep and cleaned/lubed.  Headers tend to bend and distort.  Also, check for the ports beiong sized properly... were they previously ported?.. perhaps too large?
Offline Denison636
« Reply #2777 on: January 31, 2015 - 12:41:04 AM »
What am I doing with my barracuda, well what started as a simple rebuild of a 318 turned into a rebuild of everything mechanical. I am doing the finishing touches on a totally different set up. Running a 340 punched 30 over. And also just got my heat heat going to. Hope by the end of the weekend I'll have my bumpers back on and lower pans then I can drive it for the first time in a little over two years.
Got hurt at work and held me up for a bit.
Its just a little 340 with a miss
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2778 on: January 31, 2015 - 10:38:22 AM »
Go get him Denny!  Post pics and videos!   :2thumbs:
« Reply #2779 on: January 31, 2015 - 11:51:28 AM »
I just forgot to re tighten them after repeated starts.
Initial starts it was running lean and probably over heated.
Offline dfrazz
« Reply #2780 on: January 31, 2015 - 01:12:10 PM »
I bought Stage 8 header bolts (http://www.stage8.com/mopar.html).  Put on once, snap in the lock and never have to worry about it again.
Offline 67vertman
  • Member since 9-23-2005
« Reply #2781 on: January 31, 2015 - 05:11:52 PM »
I have been a busy boy this weekend and last.
Dyed my seat belts and painted the buckles.
Took of my seat backs cleaned, sanded and painted them.
and finished my gauge cluster.
Offline roadman5312
« Reply #2782 on: January 31, 2015 - 05:15:31 PM »
Still in BODY SHOP JAIL   :walkaway:
Offline MirageCuda
  • 1974 Cuda
« Reply #2783 on: January 31, 2015 - 08:16:37 PM »
Installed a new fuel pump in the Cuda and got her running again! I miss the sound of her!
Randy
1974 Plymouth Cuda
2006 Dodge Ram 1500 SLT
1991 Nissan Skyline GTR
2002 Subaru Impreza WRX
« Reply #2784 on: January 31, 2015 - 09:20:53 PM »
I bought a set of Mr. Gasket valve cover gaskets.
The D/S valve cover was seeping a little after 3 times being off for valve adjustments.
It's about a 1-2 hour job since I have to remove the brake booster for the valve cover to lift out.
Put it all back on and now the exhaust rockers are rubbing on the inside of the valve cover.
It turns out that the thin type of gaskets they make, aren't good enough for rocker clearance.
I must use cork gaskets is the conclusion. Inside clearances are closer than I apticipated.
The good news is my spark plugs are running alot better than before since I put in the FBO ignition system.
Number 7 is the only one that's darker.
« Reply #2785 on: February 01, 2015 - 12:54:33 AM »
I bought these since they won't shrink like the Fel Pro's did.
They have a raised steel port againt the exhaust port
http://scegaskets.com/wp-content/uploads/2014/02/Pro-Copper-Exhaust-Instructions.pdf
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
« Reply #2786 on: February 01, 2015 - 08:23:38 AM »
Finished the install of the XV front level 2 suspension
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
« Reply #2787 on: February 01, 2015 - 08:36:56 AM »
They will work, but everything needs to be perfect. Less forgiving than other types.
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #2788 on: February 01, 2015 - 05:41:34 PM »
Same Here..  :bigsmile:
Offline dfrazz
« Reply #2789 on: February 01, 2015 - 05:55:40 PM »
That looks sweet!  Be sure to post a pic of the stance when you can.
