Author Topic: What are you doing with your ebody this weekend?  (Read 591512 times)
Offline jimynick
Re: What are you doing with your ebody this weekend?
« Reply #3105 on: November 01, 2015 - 10:35:36 PM »
Puttied up and boarded out the nicks and dents in the trunk floor, re-epoxied it and finished the 4th tube of sealer off going over every GD seam there is on the GD thing! Hopefully, I'll never have to deal with the rot caused between any two pieces of metal that came together in this car again. Then, I cut out the front, bottom of my nice new right side AMD 1/4 panel to get rid of the Frankenstein repair necessitated by the way I had to crank it to get it to fit. I could've mudded it up, but it's MY car and this is the way I want to go. Grandaughter showed up, so I hung up the panel cutter and slitter for another day. Please God!  :pullinghair:
Offline TelisSE440
« Reply #3106 on: November 07, 2015 - 06:23:57 PM »
Went for an alignment before a week, i did most of the work because i only knew what specs i wanted, just had a kid working there, to tell me the how the specs were changing because i couldn't see while turning the UCA bolts, a little frustrating job, but these are the specs:
Camber : Left : -1.00   Right : -1.00
Caster : Left : +1.40   Right : +1.30 (Bolts fully turned)
Toe-in : 3/32''
« Reply #3107 on: November 08, 2015 - 07:12:12 AM »
Probably all the caster you can get with stock uca and bushings.
« Reply #3108 on: November 08, 2015 - 07:22:09 AM »
Think this weekend I'll be spreading mouse deterrent in the car. Irish spring soap, bounce sheets, and traps on the floor underneath.
Snowed yesterday so probably no opportunity to drive it again until April/May 2016  :crying:
« Reply #3109 on: November 08, 2015 - 08:33:18 AM »
I tried that one year in my Buick, the mice ate the Irish spring soap and left little green terds all around the car.  :sly:
I'm running out of things to do with my car. I still haven't installed the front headlight relay set up I got from crackedback yet....... Yesterday I helped a buddy install new front end parts in his 68 Cuda  and might go help another buddy assemble his 71 Challenger that was freshly painted.  Glad to have other Mopar friends nearby to help and give me something to do as it's going to be a long winter otherwise!
Offline blown motor
« Reply #3110 on: November 08, 2015 - 08:39:00 AM »
Brad, did you put your new panels on yet?
« Reply #3111 on: November 08, 2015 - 09:12:17 AM »
No still waiting on the correct wood grain decals......
Offline Swedee
    • www.My72Challenger.com
« Reply #3112 on: November 08, 2015 - 09:19:43 AM »
Took out the 318 yesterday to freshen up the engine bay before dropping in the 360!
Check out my blog at www.my72challenger.com
« Last Edit: November 08, 2015 - 09:21:37 AM by Swedee »
Offline BS CUDA
« Reply #3113 on: November 08, 2015 - 12:23:04 PM »
 Tucked it away for the upcoming winter. Hopefully she gets to see a LOT more daylight next year.
Offline Mpdlawdog
« Reply #3114 on: November 08, 2015 - 02:26:33 PM »
I can give you one of my cats...they love challengers and mice......At least you got to drive it... mine is becoming a garage ornament....
Offline jimynick
« Reply #3115 on: November 08, 2015 - 10:41:31 PM »
Cut the rest of the kief off for the 1/4 panel repair and found some thin cardboard and made a pattern, then cut and bent the patch and trimmed it to fit. Got the zinc primer on her and mig'ged up a few holes too. Ready to weld it in and hopefully, that should be pretty much it for metal repalcement- please God! Murray, meanwhile, was swanning around sunny Stratford at a swap meet! Waaaa!  :cheers:
Offline Cudakiller70
« Reply #3116 on: November 08, 2015 - 11:51:59 PM »
New axles with green bearings installed. Going nuts trying to find upper rad hose for 340 six pack.  :eek4:
The above is just my opinion
John Adams
Offline blown motor
« Reply #3117 on: November 09, 2015 - 06:59:19 AM »
There was a dragster for sale but I didn't have $60,000 in my pocket.  :walkaway:
Offline js29no
« Reply #3118 on: November 09, 2015 - 09:16:13 AM »
 :woohoo: this has been one of the nicest Novembers I have seen here in central New York in A long time! had the cuda out last week A few times last week, drove it to church yesterday. today is sup post to be good so I will fill up the gas tank and put it up for the long winter! :crying:
« Reply #3119 on: November 09, 2015 - 02:24:34 PM »
I had mine out today , went to my sons High School and picked him up for lunch!  :bigshades:   These are the moments they will remember!  :2thumbs:
