Author Topic: What are you doing with your ebody this weekend?  (Read 591545 times)
Offline dakota
Re: What are you doing with your ebody this weekend?
« Reply #3150 on: January 03, 2016 - 09:10:13 AM »
Installing US Cartool subframe connectors.
« Reply #3151 on: January 03, 2016 - 03:36:08 PM »
Removed the battery and ign in preparation for moving both to the trunk.
Offline 70chall440
« Reply #3152 on: January 03, 2016 - 08:54:12 PM »
Got my bumper about 80% done.
Current Mopar
Past Mopars
Offline jimynick
« Reply #3153 on: January 03, 2016 - 10:00:32 PM »
I thought I'd read where you said you'd frenched the m/lamps, but it didn't really click on me until I saw the above photo. That's cool- got any pics of how you went about it?  :thumbsup:
Offline 70chall440
« Reply #3154 on: January 03, 2016 - 10:22:56 PM »
I believe that I put some on my thread http://www.cuda-challenger.com/cc/index.php?topic=108127.0
It helps if you have old fenders to use the backing plates, if not you have to use the ones you cut out of the fenders you want to do it too. Essentially, you cut out that backing plate, built a fence around it, weld it back in.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #3155 on: January 03, 2016 - 10:48:12 PM »
Here are some pics
Current Mopar
Past Mopars
Offline jimynick
« Reply #3156 on: January 04, 2016 - 10:36:53 PM »
That's about what I figured. My problem would be cutting up the new AMD 1/4's as well as the finally scrounged fenders! LOL  Are you going to do all 4? I imagine the finish grinding around the edges to arrive at a nice, smooth line would be fun! A TIG could be a guy's friend there. Nice way to personalize your car! Pls give us some pics when it's painted; I'd love to see it finished.  :thumbsup:
Offline 70chall440
« Reply #3157 on: January 05, 2016 - 01:16:23 AM »
The hardest part is cutting out the new fender. The hole has to be bigger than what you see because the marker lights are slightly pyramid shaped (fatter at the base). Where the fender begins to roll in is where it needs to be trimmed back slightly. Yes I did all 4 lights because I never liked the marker lights sticking out and they are always the first thing to get broken. I had planned to TIG them in, but ended up using a 110V MIG with .023 wire, it was quicker as I was/am not super good at TIG just yet. That said, it will be cleaned up a lot when I do the body work with a slight amount of filler to make a really crisp line.
Current Mopar
Past Mopars
Offline TelisSE440
« Reply #3158 on: January 06, 2016 - 09:20:01 AM »
Nice job, although it is difficult.  :)
Offline 70chall440
« Reply #3159 on: January 06, 2016 - 11:22:24 AM »
Thanks, there are many things like that on this car, I have done a lot of fabrication; point in case check out my high speed semi automatic antenna.
Current Mopar
Past Mopars
Offline TelisSE440
« Reply #3160 on: January 06, 2016 - 11:47:57 AM »
It really is innovative work, did you make the antenna brace for the mechanism ?
Offline 70chall440
« Reply #3161 on: January 06, 2016 - 12:04:06 PM »
Yes, I wanted something that held the antenna securely and looked decent at the same time.
Current Mopar
Past Mopars
Offline blown motor
« Reply #3162 on: January 09, 2016 - 04:08:58 PM »
Priming and painting bumper brackets.
« Reply #3163 on: January 09, 2016 - 04:44:35 PM »
Just fired it up to keep " the juice's flowing" as its 43 degrees here today!  :2thumbs:
Offline crash340
« Reply #3164 on: January 09, 2016 - 05:44:34 PM »
Just fitted some 1.06 bars in my Cuda, the original .9 bars both had a slight bend in them from factory and the drivers bar seemed to be clocked slightly off (one adjuster in more than the other by a long way) and once out confirmed the HEX is out a little.
Greg
73 Cuda
Brisbane, Australia
