Author Topic: What are you doing with your ebody this weekend?  (Read 591854 times)
Offline bb71challenger
Re: What are you doing with your ebody this weekend?
« Reply #690 on: March 10, 2009 - 11:46:27 PM »
What I get to do this weekend is pack more stuff into my restoration room. The restored rallye cluster, new bezel, new Challenger specific door handles, body bolt kit and body bumper kit should all be here by the end of the week.   :woo:
*Brett*
Offline 72bluNblu
« Reply #691 on: March 14, 2009 - 07:41:56 PM »
Finally installed my 3/8" stainless steel fuel line from inlinetube. Fit great, no problems, pretty easy installation really. Found a section of the old fuel line that was pretty much crimped off :eek4:. Also installed a fuel pressure gauge because I had previously thought the fuel pump was headed south. Turns out it was the line! 4.5 psi at idle using the old line :o, up to 6 psi at idle with the new one. Still have to drive it and put it under load to be sure, since wide open uphill was really the only time I had issues with it, but I think this was definitely the issue.  :grinyes:
sleepychallenger
« Reply #692 on: March 14, 2009 - 08:11:45 PM »
 :woo: finally got that Eddy TM6 bolted on so i can make templates for Stroker to cut off of. Only took me a couple months. those middle four bolts are a BI**H on that thing.   :roflsmiley:
Offline Oldschool
  • Member Since 9-05-06
« Reply #693 on: March 14, 2009 - 08:43:37 PM »
Well, I was chasing parts a good portion of the day....    :hyper:  But, I was still able to get the bottom end buttoned up.  I still have tomorrow, so I am going to try and get the front steering linkage hooked back up. I might also attempt that  :swear:    :stomp:     :pullinghair:    :banghead:  header hook-up.  If I get that conquered, I will install the rocker gear and set the valves.  That only leaves the intake and carb installation next weekend.  I hope it goes as planned....    :bigshades:
Ken  --  In Georgia
« Reply #694 on: March 15, 2009 - 12:42:43 AM »
Getting my steering box stripped of powder coating. Back to the original cast look. Flash casting smoothed for a cleaner look. Then send it out to Steer N Gear for a firm feel upgrade and re-build.
« Reply #695 on: March 15, 2009 - 02:14:18 AM »
Hey, I was taking pics of my car with fresh tint on it  :woo:
*Brett*
Offline 71bigblock
    • Steve's Mopars
« Reply #696 on: March 15, 2009 - 09:11:03 AM »
Man Brett does that look good.   :ylsuper: :bananasmi
I toyed around with the idea of going over and getting mine off the stands and started today.  Supposed to be low 50's.   :clueless:
Offline rallye5.7
« Reply #697 on: March 22, 2009 - 02:22:03 PM »
Went to the body shop today and went over some of the details before the paint goes on. I was given a list of items to take care of and supplies needed.
Should be seeing some color next week. I'm spending the rest of the day chasing another project.
sleepychallenger
« Reply #698 on: March 22, 2009 - 02:26:36 PM »
what are all the holes in the fender?
Offline 67vertman
  • Member since 9-23-2005
« Reply #699 on: March 22, 2009 - 02:41:39 PM »
Side scoops...it is a Challenger.... :poopoke:
Offline 71ChallengerSE
« Reply #700 on: March 22, 2009 - 08:11:08 PM »
Removed some undercoating with a torch  :faint:
« Reply #701 on: March 22, 2009 - 08:12:48 PM »
I actually put my hands on my car today and brought it home.   :bigsmile:
*Brett*
Offline 67vertman
« Reply #702 on: March 22, 2009 - 08:41:24 PM »
Rebuilt the carb and replaced all the vacuum lines.   :2thumbs:
« Reply #703 on: March 22, 2009 - 10:33:16 PM »
Put on my new T/A hood, now it's loking good! Paint next!
Offline DMZ73
    • http://www.pbase.com/dmz73/
« Reply #704 on: March 22, 2009 - 11:25:50 PM »
Ordering parts off Ebay, and making a huge ridiculous order list for YO. :clueless: :popcorn: :ebay: :clapping: :woo:
Other than that....Just staring..... :bigsmile:
Been doing bodywork for 2 years. It's time to get her rollin'
Dan
