Author Topic: What are you doing with your ebody this weekend?  (Read 591726 times)
Offline Cudakiller70
Re: What are you doing with your ebody this weekend?
« Reply #3375 on: May 29, 2016 - 09:45:36 PM »
It is not "correct", nor is it pretty, but it should be sufficient for the car's second life. Giving Eastwood's "Rust Encapsulator" a shot, applying Lizard Skin Ceramic coating to the floor boards and RaptorLiner bedliner to the wheel wells and parts that expect to see jackstands when I work on it.
I've seen the complete under side of cars sprayed with a low gloss black bed liner (some even tinted body color) and thought it looks very clean myself. FWIW you could spray bed liner over the lizard skin giving the underside continuity. Not trying to tell you how to do it just throwing it out there.  :dunno: Some like it some people don't  :2cents:
Good luck  :cheers:
The above is just my opinion
John Adams
Offline GoodysGotaCuda
« Reply #3376 on: May 29, 2016 - 10:05:21 PM »
Good luck  :cheers:
I plan on top coating the lizard skin in gloss black, it should have a similar finish when compared to the Lizard Skin when done, not identical, but close enough for me. :working:
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3377 on: May 29, 2016 - 10:58:36 PM »
:2thumbs:
John Adams
Offline nicka
« Reply #3378 on: May 30, 2016 - 08:28:32 PM »
Leaf spring removal. Needed  the bar off the hydraulic jack for leverage.
Casters 800+lb each arrived. Cut/drilled 4" x 1/4" flat bar. Planning to move the Barracuda out back.
« Last Edit: June 02, 2016 - 12:32:44 PM by nicka »
Offline jimynick
« Reply #3379 on: May 30, 2016 - 10:00:48 PM »
Spent 2 hrs cleaning.vacumning the garage and then another couple sanding/washing/tacking the engine compartment/cowl/frt frame rails and hinge pillars and then I painted them in single stage. I've still got to paint the other side of the undercarriage and then I can start to put in the brake and fuel lines.
Offline SirRalliart
« Reply #3380 on: May 31, 2016 - 05:32:28 AM »
The Cuda is getting jealous as I'm spending all of my car time doing a Lean Burn conversion on the Street Kit Car.  I'm installing a Weiand Action+, Street Demon 625, Rev-n-nator, Firecore distributor and coil.  In addition, I'm painting parts as they come off.
1971 Dodge Challenger R/T (Top Banana)
1972 Plymouth 340 Duster (TX9 Black)
1974 Plymouth 'Cuda360 (Deep Sherwood Metallic)
1978 Plymouth Volare Street Kit Car (#43, 2-tone Blue)
2014 Dodge Ram 1500 (Pitch Black)
2015 Dodge Charger SE (Granite)
2015 Dodge Callenger Hellcat (Phantom Black)
Offline BS CUDA
« Reply #3381 on: June 04, 2016 - 06:16:27 PM »
Finally got to run the 'Cuda at the track last night. Best pass was a 11.86 @ 112mph, 1.66 60',and .01xx and .03xx reaction times oh and a red - fastest she has ever run but somewhat disappointed as it should be a lot quicker than that. I suppose not bad for 1st trip out. Did zero tuning last night and certain that will help tick off some tenths next time out.
She used to run 12.0 with the Eddy heads - these Indy Big EZ 325's should produce a lot better results.
« Reply #3382 on: June 05, 2016 - 10:12:42 PM »
I went out in the garage all day Saturday, tunes cranked and mocked up the stock cast iron water pump housing to replace the big time restricted 440 source housing and while I was at it I made a new thermostat housing and brackets to mount the circle track power steering pump I've had for a year now....
« Reply #3383 on: June 05, 2016 - 10:23:43 PM »
Nice work Brad.
You've got true talent.
Wanna move out here?
I'll get you a job no time flat!   :biggrin:
« Reply #3384 on: June 05, 2016 - 10:30:03 PM »
Nice work Brad.
Thanks, tempting......
« Reply #3385 on: June 05, 2016 - 10:39:29 PM »
Based on what I've seen you do, you can make anywhere from 25-35 an hour...Maybe more.
CNC is desperately needed out here but I do have a few shops that are looking for old school machinists.
Offline Jamiez
  • Retro
« Reply #3386 on: June 12, 2016 - 10:48:35 PM »
Offline blown motor
« Reply #3387 on: June 13, 2016 - 08:19:18 AM »
Went for a cruise to jimynick's to check out the progress of his restoration. You know, just to make sure he was doing it right.  :poopoke:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #3388 on: June 13, 2016 - 01:11:42 PM »
Celebrated my birthday with some Mopar buddies.
« Last Edit: June 13, 2016 - 01:15:02 PM by dfrazz »
« Reply #3389 on: June 13, 2016 - 03:01:23 PM »
Very cool! Happy Birthday!!!
