Author Topic: What are you doing with your ebody this weekend?  (Read 591972 times)
Offline 422STROKER
  • Member Since 6/3/06
Re: What are you doing with your ebody this weekend?
« Reply #360 on: August 27, 2008 - 04:01:53 PM »
Going to dragway tonight.LOL
Tom :bigsmile:
Tom
Offline sadil340
« Reply #361 on: September 06, 2008 - 12:12:14 PM »
Putting in my drive train!! :jumping:
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline 422STROKER
« Reply #362 on: September 06, 2008 - 12:13:23 PM »
 :useless:
Tom :bigsmile:
I'm driving 1.5hrs to a BBQ tomorrow to hang with some Mopar nuts!
Tom
Offline GoodysGotaCuda
« Reply #363 on: September 06, 2008 - 01:17:43 PM »
Tom :bigsmile:
post video!
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline RDF
« Reply #364 on: September 06, 2008 - 01:20:12 PM »
We started a new schedule at work, 9/80, so I have every other Friday off now.... :woohoo:
So yesterday was my first Friday off and I put my back seat together and in my car, changed the position of my hood pins, fixed a ground that was problematic for the longest time and was going to do front brakes but when I took them off, the meat on the pads were brand new.....so I've got some squeaking coming from the passenger side front disc when I come to a stop, I may just have them cut the rotors to see if that helps.....but a good, productive day for me and my car!  :2thumbs:
Going to a cruise-in tonight with Goody, DanGoodmanJR and a few others....should be fun!
Bob
1973 'Cuda
My build:
Offline 422STROKER
« Reply #365 on: September 06, 2008 - 01:24:56 PM »
post video!
Tom :2thumbs:
Tom
« Reply #366 on: September 06, 2008 - 01:32:44 PM »
Cool videos! Sounds to me like the bottom end is pretty soft though, I know you were spinning, but it really wakes up after you get off the line a little ways. What gears/converter are in it? Or is it just me?
1976 Dodge Warlock
Offline 422STROKER
« Reply #367 on: September 06, 2008 - 01:36:18 PM »
3.23's and a 2500 stall.  I don't punch it for the first 30 feet or so.  Only way I get some traction?
I'm in the process of getting some m/t drag street radials.  Hopefully that will allow a decent launch.  I'm leaving basically at idle(900rpm), the only time I tried to leave above (1500rpm) it spun bad all the way through first to the shift light.
Tom
Tom
« Reply #368 on: September 06, 2008 - 01:38:46 PM »
Ah i see, there is a ton left in that car once you get it dialed in!
1976 Dodge Warlock
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #369 on: September 06, 2008 - 01:41:44 PM »
I'm riding out tropical storm Hannah right now. Can't do much as it's pretty nasty today. :crying: I do most of my work under the carport. A little too windy/rainy. I really want to drop in the new rear end (3:91 posi) I just got from Moparal and then go and do like Tom and burn some rubber!! :woo: Sunday looks like it will clear out. Maybe I'll start then. Sounds like you've really been enjoying your car Tom. Glad to hear it. It's one sweet ride!! :2thumbs:
                                                               Matt B.
Matt
Offline 422STROKER
« Reply #370 on: September 06, 2008 - 01:53:09 PM »
Thanks Goody and Matt!
Been enjoying it all summer long.
Goody, I only hope when I get the power down that the racing doesn't take too much of a hold.LOL  Like adding gears and such to it.  I haven't disconnected the front sway bar yet either, maybe next time with better tires.....
Tom :bigsmile:
Tom
« Reply #371 on: September 06, 2008 - 01:58:22 PM »
don't forget to pump up the front tire psi for less rolling resistance too! Not sure if you do, but after the burnout, rev it up in neutral a couple times to help clear the engine out. Letting off the throttle quick after the burnout may load up the plugs a little.
1976 Dodge Warlock
Offline 422STROKER
« Reply #372 on: September 06, 2008 - 02:02:40 PM »
I'll have to remember that, I drove the car there and left the tires the way they were, 35psi and then drove home it was 100+miles round trip.
Tom :smilielol:
Tom
« Reply #373 on: September 06, 2008 - 02:06:41 PM »
Yep, I used to take a little cheapo 12v 'tire inflator' with me and bumped them up to 45 or so (whatever is max on the sidewall). Then I'd just let it back out before heading home. You may try adding weight to the rear end if you are waiting on new tires. Sandbags over the axle in the trunk, I got my best e/t  on street tires by adding a full size floorjack and all the tools i could find to the trunk. Added traction/harder launch will outweight the actual weight!
1976 Dodge Warlock
Offline 422STROKER
« Reply #374 on: September 06, 2008 - 02:15:03 PM »
I got this in the trunk, it's pretty heavy.lol 2-10" subs and made from 3/4"plywood.
Tom :working:
By tdavist, shot with DSC-P72 at 2007-12-08
Tom
