What are you doing with your ebody this weekend?
Author Topic: What are you doing with your ebody this weekend?  (Read 591107 times)
Offline bb71challenger
Re: What are you doing with your ebody this weekend?
« Reply #2040 on: September 21, 2012 - 09:10:34 PM »
picked up my cherry picker from dads place yesterday, moving things around so I can get at my fully assembled 400 and start pulling accessories off, draining oil, etc for engine disassembly. looks like I am finally gonna put a motor together and get this damn thing finished!
*Brett*
« Reply #2041 on: September 21, 2012 - 10:48:04 PM »
Well if the raim hold off I'm taking the Snot Rod out for it's maiden vovage with the new motor, tranny and rear end! Hope nothing falls off or blows up! :swaying:
Offline DoNotChallengeHer
« Reply #2042 on: September 22, 2012 - 01:01:20 AM »
:burnout: :burnout:   :clapping: :clapping:
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2043 on: September 22, 2012 - 02:24:44 AM »
I`m finally going to dig into the cuda to track down and hopefully fix the intemitant starting problem so maybe I can take it out a few times this year before the seasons over.
Let me know if you need a hand Jeff
Tom
Tom
Offline msbaugh
« Reply #2044 on: September 23, 2012 - 03:32:43 PM »
Do you have a ground connection between the sender and the block?  Maybe there is too much teflon tape and you have not electrical path through the sending unit.
I would try holding the wire to the housing of the sending unit.
The ground is good on the water pump housing.  Finally got the gauge working but it sits way low... I think the new thermostat I put in might be jammed or stuck open.  Looks like I'll be getting a new one
« Reply #2045 on: October 06, 2012 - 10:17:27 PM »
Installed the rear Cuda surround trim today. Was kinda tricky and took longer than I anticipated.
Looks killer now.
Oh yeah, a few other things underway...
Guages were sent out to Hayward Auto Instruments for the worm gear to be replaced and the guages checked out.
Top of the door trim goes out this upcoming week to be anodized.
Rear de-fog was installed.
« Last Edit: October 06, 2012 - 10:33:54 PM by Topcat »
Offline GranCuda1970
« Reply #2046 on: October 06, 2012 - 11:40:38 PM »
Better attached the windshield trim, installed the wipers arms and blades, pounded out a small dent in the front passenger fender.
Offline spamtank
« Reply #2047 on: October 07, 2012 - 07:53:22 AM »
Took her for a ride out past the lake, enjoying the fall foliage here in NH.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline jordan
« Reply #2048 on: October 07, 2012 - 10:03:39 AM »
My plan is to scrape some undercoating off of the inner fender and add my XV shock tower bracing.  Everything lines up nicely, but I need a clean surface as to not contaminate my welds.  As long as I do something every day, it will eventually get done.  All of this is still dependent on my job.  If nobody needs emergency brain surgery today, then I can get it done.
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #2049 on: October 07, 2012 - 03:44:48 PM »
Seriously, brain surgery?
That must be one cool job.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #2050 on: October 07, 2012 - 08:01:59 PM »
Installed a new high torque mini starter and a positive battery cable and starter relay.  Man what a difference!
Then I gave it a wash. Time to start winterizing it. Installing the wipers, and resealing the back window.  It does not rain here in the summer from May to November and I plan on driving it this winter.  I might even consider installing a heater valve and a new cable and getting that working.
Offline 360FISH
  • BS23H3B567746
« Reply #2051 on: October 07, 2012 - 11:49:02 PM »
More grille repair...  hope to have primer on it by mid week and painted soon after.
http://www.cuda-challenger.com/cc/index.php?topic=74674.75
I want to drive my car again!!!    :burnout:
1973 ‘Cuda   Semi-Pro Touring
Offline jordan
« Reply #2052 on: October 08, 2012 - 01:24:12 PM »
'Cuda Hunter, seriously, yes, brain surgery.  I am a nurse in a level 1 trauma hospital operating room.  I work on the neurosurgical service, and set up and assist in brain and spine surgeries as my specialty, as well as just about anything else that can come through the door.  Work left me alone on sunday.
      I did get my gussets welded up and welded my shock mount sheet metal to the inner fenders.  I will get the tubular bars welded in yet this week since I am working a late shift this week.  Hopefully it will all be finished by the weekend including removing my pinch weld at the firewall to trans tunnel so my OD trans fits.  That reminds me, I should ask Brad about that.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #2053 on: October 09, 2012 - 09:09:28 AM »
Got the cuda out for her first long drive of the year yesterday.Had the day off work and decided to go apple picking up north.Got gassed up and only made it ten minutes before alt gage went to D but after turning around to go home it went back to charging and we risked it and ran fine the rest of the day.Put about 100 miles on her down some nice winding/hilly back roads with no traffic so really got to have some fun!  :burnout:  :bigsmile:
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
« Reply #2054 on: October 10, 2012 - 10:16:23 PM »
Bet it was a beautiful ride there this time of year as the leaves as changing.
Kicking leaves while winding down the road.  :bigshades:
