Author Topic: NEED MANY PARTS FOR DODGE CHALLENGER..HELP!!!  (Read 738 times)
Offline 4THECHALLENGE
« on: April 24, 2008 - 09:17:18 PM »
HELLO ALL. IM WORKING ON A CHALLENGER THAT WAS EQUIPPED WITH A 318 BUT ILL BE INSTALLING A 340 AND NEED ALL THE SMALL ACCESSORIES LIKE MOUNT BRACKETS, BRACKETS FOR ALTERNATOR, POWER STEERING PUMP, ALL CABLES (THROTTLE) I ONLY GOT A 340 MOTOR IT HAS AN INTAKE, VALVE COVERS, I NEED ALL THE LITTLE ACCESSORIES.HOW MUCH AND WHO HAS THEM??
THANKS  :working:
Re: NEED MANY PARTS FOR DODGE CHALLENGER..HELP!!!
« Reply #1 on: April 24, 2008 - 09:18:17 PM »
ALSO NEED DOOR PANELS FOR THE FRONT AND REAR. IN DRIVER SHAPE.
THANKS
« Reply #2 on: April 24, 2008 - 09:26:43 PM »
I'm pretty sure most everything from the 318 is the same for the 340... exception would be the throttle bracket, cable should be ok.
Mancini has a pretty good run down of the more common items but others may have to be found at more specialized sources,
http://chucker54.stores.yahoo.net/engine.html
http://chucker54.stores.yahoo.net/restoration1.html
« Last Edit: April 24, 2008 - 09:30:22 PM by bullitt99 »
« Reply #3 on: April 24, 2008 - 09:41:32 PM »
So whatcha got fersale newbie?  Yer in the forsale section and not want section
