Author Topic: Ballast Resistor  (Read 1743 times)
Offline Harts56
    • 70 Challenger Convertible
Ballast Resistor
« on: April 25, 2008 - 04:10:57 PM »
 :clueless:  I have a 70 Challenger 440 with Chrysler electronic ignition.  It was already in the car when I bought it.  Car runs well.  This week I had to replace my coil and I actually read the instructions and now have this question:
Coil is Petronix Flame Thrower 1.5 ohm 45K volts.  The instructions say to remove the ballast resistor.  Why?  Will it hurt anything?  If I pull the ballast resister out of the circuit do I just connect the wires together that currently run to it?  The car is a street car, max RPM's are 5500 to 6000.
Anyone out there who can educate me?
Thanks,
John
Re: Ballast Resistor
« Reply #1 on: April 25, 2008 - 04:28:03 PM »
John,
  I'm not up to speed on Pertronix coils, but my guess is that 1.5 OHM rating includes a built in ballast resistor. That way the coil won't see the full 12 volts.
Yes, you can just connect the two wires together after you remove the ballast resistor.
« Reply #2 on: April 26, 2008 - 03:24:39 AM »
the 1.5 Ohm is the drop needed to the coil typically , so I think you stillneed the ballast , what Exactly do the instructions say about removing the ballast , most coils do not have a built in resister ?
Offline Harts56
« Reply #3 on: April 26, 2008 - 12:09:41 PM »
Mistake on the coil, it is a Flamethrower 40K petronix part # 40111
Instruction are very generic.  Shows this coil has a 1.5 Ohm drop.  I measured the following:
1. Battery voltage with key off, 12.92 V
2. Measured at coil with ignition energized (engine off) 4.7V
3. Jumped ballast resistor and measured at coil again 6.63V
Voltage seems to be low, but I do not see any other ballast resistor or anything else to reduce voltage.  All wiring is wrapped so I am unable to see if there is something "inline" with the wiring.
Wiring looks like from the ballast resistor it also goes to the electronic ignition control unit, if I disconnect this I do not want to fry the ECU.
I guess at this point I nee to know what the voltage should be at the coil?.  Any ideas?
« Last Edit: April 26, 2008 - 01:29:47 PM by Harts56 »
« Reply #4 on: April 27, 2008 - 03:24:47 AM »
typically around 8V measure it running though
Offline Harts56
« Reply #5 on: April 28, 2008 - 02:10:51 PM »
 :clueless: With engine running 4.8-5.0 volts.
« Reply #6 on: April 28, 2008 - 02:35:01 PM »
What side of the coil are you getting these measurements from? It sounds like the negative side, which would make these correct.  :1zhelp:
Offline Aussie Challenger
« Reply #7 on: April 29, 2008 - 06:25:31 AM »
  Some of the later hi energy coils require 12 volts, if you are running with that lower voltage it could be that your coil is shorting out internally, disconnect the neg. side and see if the voltage goes up, it should if there is no short.
Offline iron6
Re: Flame Thrower Coil and stock Ballast Resistor
« Reply #8 on: March 09, 2009 - 08:03:40 PM »
I didn't see an answer to this question.  Do you disconnect the ballast resistor when using a flame thrower coil?
« Reply #9 on: March 09, 2009 - 09:40:00 PM »
the flamethrower should use a ballast
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #10 on: March 10, 2009 - 06:58:35 PM »
havent used one with that coil, almost 20k miles, no problems.
