Author Topic: Water pump housing torque question  (Read 1320 times)
Offline MDMoparDude
« on: April 25, 2008 - 10:20:13 PM »
I just bought an aluminum water pump housing fromm 440 source.  When I asked them for the torque specs, they said they didn't have any???????  Any suggestions.....  Dont want to strip it out.............
Re: Water pump housing torque question
« Reply #1 on: April 26, 2008 - 03:21:12 AM »
pump to block is a
3/8" bolt so I would use around 30ft lbs  max
 poroabaly 20-25 for the pump to housing bolts
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #2 on: April 26, 2008 - 03:40:05 AM »
From 1973 Chassis Service Manual Plymouth/Chrysler/Imperial:
Water pump Installation (400-440 Engines)
(1) Using a new gasket, install water pump and tighten retaining bolts to 30 foot-pounds.  Rotate pump by hand to be sure it turns freely.
This is for the water pump only, not the housing.  Chryco Psycho sounds dead on with 20-25 foot lbs.
« Last Edit: April 26, 2008 - 03:45:27 AM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline MDMoparDude
« Reply #3 on: April 26, 2008 - 08:49:31 PM »
Thanks, I didn't want to use the manual specs because the originals were cast iron, and I know I could stand on the wrench.
