Author Topic: Subframe connectors  (Read 4273 times)
Offline mjb765
Subframe connectors
« on: April 26, 2008 - 10:03:08 PM »
Does anybody make a BOLT-IN subframe connector for a 70 challenger?? All I can find is weld in......my bolt in skills are better than my welding
Offline GoodysGotaCuda
Re: Subframe connectors
« Reply #1 on: April 26, 2008 - 10:09:53 PM »
Mopar makes bolt-in kits i believe. Try searching through summits online catalog. However i hear the drilling for the bolts is a pain, and welding is a lot more structurally sound.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: April 26, 2008 - 10:12:56 PM »
Yes, MP has them but they aren't really bolt -in.LOL  I'm going to have mine welded by someone later on.
Tom
Tom
Offline mjb765
« Reply #3 on: April 26, 2008 - 10:19:34 PM »
I've read that the Mopars are not really bolt in also. I guess I will start thinking about the weld in ones. Thanks
Offline 422STROKER
« Reply #4 on: April 26, 2008 - 10:25:27 PM »
Yeah the mopar ones will bolt in but don't look to pretty.LOL
Tom
By tdavist, shot with DSC-P72 at 2008-04-19
Tom
Offline mjb765
« Reply #5 on: April 26, 2008 - 10:28:46 PM »
Did you notice a difference after they were on?? Does it help maintain the door to fender gaps when the car is being raised in the front only??
Offline 422STROKER
« Reply #6 on: April 26, 2008 - 10:36:27 PM »
Yes there is a difference, I had the car up on stands today and the doors where good.
Tom
Tom
Offline mjb765
« Reply #7 on: April 26, 2008 - 10:38:01 PM »
and the mopars go in with no cutting of the floor? Truly bolt in?? I read that they weren't really all bolt in..I hope I read wrong.
« Reply #8 on: April 26, 2008 - 10:40:59 PM »
They dont 'bolt-in'. 'bolt-in' means there are exisiting holes you use. You have to drill the holes in your frames to install those subframes.
1976 Dodge Warlock
Offline mjb765
« Reply #9 on: April 26, 2008 - 10:42:22 PM »
that still sounds good. I meant using bolts as opposed to welding them in.
Offline hemiken
« Reply #10 on: April 26, 2008 - 10:44:00 PM »
I remember someone posting they had to cut a little of the connectors to make them sit right with an angle grinder aswell. :22yikes:
Offline mjb765
« Reply #11 on: April 26, 2008 - 10:52:16 PM »
I can live with that... :working:
Offline 422STROKER
« Reply #12 on: April 26, 2008 - 11:09:34 PM »
The only thing besides the connector(instructions) was a small spot where the two floor pans meet.  Actually I just sliced it and bent them up, I could bend them back and weld up if needed.
Tom
There is a small flange or lip there, that is where I cut it.  Tough to see.
Tom
Offline mjb765
« Reply #13 on: April 26, 2008 - 11:32:53 PM »
you notched the floor where the front and rear pans meet?
Offline Aussie Challenger
« Reply #14 on: April 26, 2008 - 11:36:36 PM »
  There is another vendor who makes twin tubular frame connectors, cannot remember who as it was on the hard drive that crashed. They were powder coated and bolted straight in.   :cooldancing:
