Author Topic: Add-a-leaf. Bye bye air shocks!  (Read 14429 times)
Offline Padawan
  • Noob!
Re: Add-a-leaf. Bye bye air shocks!
« Reply #30 on: September 25, 2012 - 01:46:36 PM »
Sorry to resurrect such an old topic. I should also add a leaf as my Chally's rear-end sags quite a bit and hits the ground when exiting the garage with more than 1 passenger. :eek7:
Now my question is, Summit's 13122 seem to be the leafs that some guys here used, but they are 2.3" wide. My leafs are 2.5" wide, is that correct and I should go ahead or did you guys have 2.3" wide leafs to begin with?? :clueless:
1970 Challenger RT/SE 383
Add yourself here and then find others on the map
Offline shadango
« Reply #31 on: September 25, 2012 - 05:09:31 PM »
The part # you referred to is what I used and it worked just fine.
Offline Padawan
  • Noob!
« Reply #32 on: September 26, 2012 - 10:35:28 AM »
Cool, thanks for confirming!  :thumbsup:
Offline shadango
« Reply #33 on: September 26, 2012 - 05:34:02 PM »
No problem.
Now, keep in mind that if you are looking for a like-stock ride (or appearance) this is not your solution.
The butt end is definately raised and the ride is stiffer.  Not what I consider toooo harsh or uncomfortable, but definitely stiffer.......I love how it looks.
Offline ShelbyDogg
« Reply #34 on: September 26, 2012 - 07:20:07 PM »
Wow, that's high.
As long as you like it that way, thats all that counts.
Offline challengermaniac
« Reply #35 on: September 26, 2012 - 08:49:20 PM »
Recommend you consider having the originals rearched as the ones I got from Summit were too low and they were made in China which didn't work for me.  I tried adding leafs and just didn't get the lift I was looking for.  Go with a rearch of the originals!
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Offline shadango
« Reply #36 on: September 26, 2012 - 09:59:14 PM »
How much lift were you looking for??????    The adda leafs I sued (above) gave me like 4-5" of lift over the stock height as i recall....of course, mine were saggy to begin with.....
re-arching leaves can work but they can also settle back down over time I am told....plus you still have to experiment.
The add a leafs are cheap and havent settled so far...they are pretty thick....
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #37 on: September 26, 2012 - 11:41:57 PM »
For those who have modified their leaf springs I am curious to what choice in rear shocks did you go with?
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline ShelbyDogg
« Reply #38 on: September 27, 2012 - 02:55:10 AM »
I went to rockauto.com and bought gas charged replacements for all 4 corners for both cars. Less than $20 each for Gabriels or Monroes. You can get KYBs for $23.   My cars ride as smooth as a new car. New shocks are nice! Just drove 800 miles last week-end.
Offline shadango
« Reply #39 on: September 27, 2012 - 04:58:53 AM »
I went with the KYB gas charged shocks......would have to go back and look, but as I recall the shock # is from a pickup......they are a little longer to give some extra travel due to lifting.     A stock length shock would bottom out.
Offline MTS-Challenger
  • Vanishing Point - "Catch Me If You Can"
« Reply #40 on: September 27, 2012 - 03:30:12 PM »
I used Mr. Gasket 1288 Rear Shock Extensions Vs. using longer shocks  :2thumbs:
« Last Edit: September 27, 2012 - 06:22:30 PM by mttchall »
1970 Challenger R/T 440
Offline Padawan
  • Noob!
« Reply #41 on: September 30, 2012 - 05:12:42 PM »
That is a little high indeed! I'll probably look into re-arching the originals around Boston.
Offline johannes
« Reply #42 on: November 03, 2012 - 06:55:19 AM »
Shadango. NICE STANCE !!!
May I ask you to take a picture of the rear chackle?
Is it sloping backwards from top to bottom still?
