Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Fuse block
« previous
next »
Print
Pages: [
1
Author
Topic: Fuse block (Read 1306 times)
71FJ6
Jr. Member
Fuse block
on:
April 27, 2008 - 08:53:16 AM »
On a 71 Challenger what holds the fuse block to the bulkhead(if I am using the right term)?Mine is loose and I only have power to the left row of fuses.
Thanks,Dave
Logged
matt63
Sr. Member
Re: Fuse block
Reply #1 on:
April 27, 2008 - 09:23:04 AM »
If I remember correctly the block has 4 flexible plastic clips (part of the block) that push through the square hole in the firewall.
Logged
Matt in Edmonton
'68 Valiant
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: Fuse block
Reply #2 on:
April 27, 2008 - 09:46:44 AM »
The left bank has constant power...the right bank is switched, turn the ignition switch on or accessory, if you still don't get power there may be issues w/column wiring
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Chryco Psycho
Administrator
C-C.com Guru
Re: Fuse block
Reply #3 on:
April 27, 2008 - 12:04:27 PM »
the bulkhead plug is bolted to the firewall , there are 2 steel spring clips that hold the fuse block to the rear the bulkhead plug
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Fuse block
