Door glass problem
Author Topic: Door glass problem  (Read 857 times)
Offline 71FJ6
Door glass problem
« on: April 27, 2008 - 10:24:47 AM »
If you grab either side of the door glass on my Challenger you can move it up and down.In rolling it up you have to pull up an the front to get all the way up. The guides look okay,could it be the regulator?
Thanks,Dave
Re: Door glass problem
« Reply #1 on: April 27, 2008 - 12:07:28 PM »
I do not see it being the regulator , you must be missing part of the guide pieces
Offline 71FJ6
« Reply #2 on: April 27, 2008 - 06:06:40 PM »
It pretty much went together like the passenger door which works fine.
To make a long story short someone else took them apart and put all the parts in a box.Even with a guy from a glass co. it was a struggle to get it back together.I ended up with the bracket looking pieces with a rubber cap on them left over.Just couldn't find any place for them in the doors or quarters.
I have a 70 shop manual but it doesn't get into that fine of detail.
Offline IMNCARN82
  • LeDZeP
« Reply #3 on: May 04, 2008 - 09:57:11 PM »
Mayby this will help. Good luck.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« Reply #4 on: June 01, 2008 - 03:46:40 PM »
Hi
I belive that are the upper stops in doors. There are a hole in the glass so you can adjust the stops when the glass are in and up.
Hope its helps. If not do you have a picture of the bracket.
See picture
Best regards
Dennis
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
