Author Topic: Recommend using(or not) rallye vinyl stick-on for instrument cluster?  (Read 1134 times)
Offline priderocks
I could spring for the $175 for new metal, or $25 for the vinyl stick-on for my wood grain rallye instrument cluster. I am about ready to try the vinyl, except I have this same nagging voice in the back of my head that happens whenever I think of hanging wallpaper. I've also heard the stick-on stuff doesn't stay stuck on. Any recommendations?
Offline bb71challenger
Re: Recommend using(or not) rallye vinyl stick-on for instrument cluster?
« Reply #1 on: April 27, 2008 - 12:51:11 PM »
Although it is so cheap I am tempted to try it, the negative remarks from members here make me realize I am better off waiting and buying the whole thing. Just my  :2cents: but I would listen to that nagging voice, do it right the first time and be done with it. Good luck!
*Brett*
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: April 27, 2008 - 01:16:31 PM »
I did the stick on and I would not reccomend it. If you have the money just order a new one you are definitely better off.
1996 Dodge Viper GTS Coupe
Offline Katfish
  • 70 Challenger
« Reply #3 on: April 27, 2008 - 01:21:58 PM »
 :iagree:  Listen to that little voice, stay away from the stick on.  My bubbled in less than a yr.
Offline 70challrtse
« Reply #4 on: April 27, 2008 - 01:30:27 PM »
You can also get your existing one restored.
« Reply #5 on: April 27, 2008 - 02:02:38 PM »
Buy the metal for $175. There's no messing around with air bubbles.   :thumbsup:
Offline CrazyPete
« Reply #6 on: April 27, 2008 - 05:52:21 PM »
i did the one on my t/a years ago it was a pain the first 2 holes were perfect the last 2 sucked i ended up making a cut in the vinal and it turned out ok you can hardly tell where the cut is.
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
« Reply #7 on: April 27, 2008 - 06:16:06 PM »
I was going to go stick on and was planning on installing it with soapy water like a decal and then useing a small squeiggy(spelling) but opted out for the whole panel piece so I could get the wholepanel with  the chrome around the holes too
Offline 472 R/T SE
« Reply #8 on: April 27, 2008 - 07:08:09 PM »
$175, wow, something cheaper for an e body verus b body.  That's a first.
For that price I would avoid the stick on.  Mine's bubbled as well and the fact that the sticker doesn't go around the edge of the gauges bugs me every time I get behind the wheel.  Most folks will have to look for it but it bugs the hell out of me.
HELP SUPPORT THE REGISTRIES because all cars matter.
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Offline 73Chally
« Reply #9 on: April 27, 2008 - 07:14:48 PM »
Okay, I just want to play the devil's advocate  :villagers: .  Is there anyone out there that has had a good experience with the vinyl stick ons?  I bought a set from the Detroit something or other company a while back and put them on about 2 months ago, but the dash has not been put in the car, yet.  I admit the $25 vs $175.00 is what made me go this route, but if they are as bad as most people seem to say, then I would consider buying the new tins down the line.  Any thoughts?  Thanks.
Offline CrazyPete
« Reply #10 on: April 27, 2008 - 07:33:54 PM »
for the money it was an improvement for me i had a wicked scratch on my wood grain that really bugged me alot.........and mine has yet to bubble ive had mine for a pretty long time
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #11 on: April 27, 2008 - 11:47:51 PM »
I have done 2 cars with vinyl and very good results. I would do it again. I made sure the panel was clean and applied the decal exactly as the instruction stated. I think I ended up using a hear dryer at the end to shrink it up a little.
2013 Tige' RZR 343hp
Offline 71340RT
« Reply #12 on: April 28, 2008 - 01:00:06 AM »
My vinyl looked good for about 2 years but is starting to bubble on my Challenger now so I'm wanting to go with the new metal piece now.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline Aussie Challenger
« Reply #13 on: April 28, 2008 - 06:20:54 AM »
  I haven't done the Challenger, however I have applied vinyl to similar surfaces before. I always have made sure that the surface was clean, the temp. of the panel was warm, not hot, then carefully applying without stretching the vinyl. The finished products lasted many years inside the car.
Offline miketyler
    • www.miketyler.net
« Reply #14 on: April 28, 2008 - 07:21:22 AM »
I did the vinyl on my car and it looks great. Has been at least a year and no bubbling. However, the insets around the turn signals did release. I tried using contact cement but the vinyl didnt like it. I would do it again. Maybe apply a little heat and place a wooden dowel or other round object in the hole to get the vinyl to conform to the inside of the hole.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
