Author Topic: 4- speed shifter  (Read 2962 times)
Offline jackie
4- speed shifter
« on: April 28, 2008 - 04:00:43 PM »
anyone have a V-gate 2 shifter.if so how do you like it?
1970 challenger r/t, prostreet 438 ci. 4 speed
Re: 4- speed shifter
« Reply #1 on: April 28, 2008 - 06:18:39 PM »
  :clueless:
« Reply #2 on: April 28, 2008 - 07:05:22 PM »
I had one years ago. But you have to butcher up the floor to make it fit. good for not missing gears though
Offline jackie
« Reply #3 on: April 29, 2008 - 07:29:37 AM »
how about a super shifter? what do you use?
Offline jackie
« Reply #4 on: April 30, 2008 - 07:17:38 AM »
come on guys, i know that i am new here,but does everyone here have a auto. or all stock shifters?
Offline moparclown
« Reply #5 on: April 30, 2008 - 07:34:58 AM »
Hello
Are you looking for 4spd shifter pics or auto shifters?I have a B&M in my 69 cuda,mounted in the console.
Offline jackie
« Reply #6 on: April 30, 2008 - 10:05:13 AM »
thanks, i am thinking about replacing my comp.plus,4-speed shifter. was asking if they had anything diff. that they liked better. i have looked at super shifter's and the v-gate-2. i would like to see how someone with the v-gate-2 liked it. thanks again..
« Reply #7 on: April 30, 2008 - 11:50:07 AM »
I have friven V gates in the past , they are Ok just bit clunky to down shift , mostly I use the Comp + shifter & no I never learned how to drive an automatic
Offline jackie
« Reply #8 on: April 30, 2008 - 02:26:35 PM »
thanks,it's hard to go wrong with a comp. plus..just checking out anything diff.
Offline ShelbyDogg
« Reply #9 on: May 01, 2008 - 09:11:01 AM »
I've driven a vertical gate.  It's good for drag racing because it basically gets rid of the "H" pattern and you can easily speed shift between 2nd and 3rd quickly.  It will strengthen your index and middle finger tendons by repeatedly pulling the lever for 1st and 2nd, and downshifting to those same gears from higher gears. Jackie, if you don't have a strong right wrist, you will after using this shifter for a while.
For those who don't know what a Hurst V-gate shifter is;   the handle has 2 positions, pushed forward and pulled back.  The top is a T- handle. It has a 2 finger handle in front of it that you pull up, while shifting, for 1st or 2nd.  If you didn't pull up on the finger lever and just pushed forward, you would hit 3rd, pulling back, 4th.  It also has a small reverse lockout lever sticking out on the left side, requiring 2 hands to find reverse.
This shifter is great for speed shifting in drag racing, where your right foot NEVER lets off the gas while shifting. For regular street racing and everyday driving, if your shifter mechanism is clean a lubed, a regular competition plus shifter is an all around better shifter.
Offline jackie
« Reply #10 on: May 01, 2008 - 09:53:44 AM »
thanks Rob, that was the answer i was looking for. looks like downshifting would be a pain. better to ask now ,than buy it and not like it later..but man it looks good..
Offline ShelbyDogg
« Reply #11 on: May 01, 2008 - 10:07:02 AM »
Glad to help out Jackie.
Downshifting isn't a problem, there is just an extra step. For instance, going from 4rth to 2nd; push forward for neutral, pull lever up, pull back for 2nd.
btw, for any Mopar or Non-Mopar drivers with a automatic, The original pistol grip shifter looks GOOD!
