Author Topic: How far back for H-pipe?  (Read 5089 times)
Offline 422STROKER
  • Member Since 6/3/06
« on: April 28, 2008 - 08:41:36 PM »
I got a H-pipe kit to cut in and I have to put it back by the front of the driveshaft due to pipes not being straight until there.  How far back before it becomes an issue?  I mean is it detrimental to performance in anyway or does it not matter?
Tom :1zhelp:
Tom
Offline GoodysGotaCuda
Re: How far back for H-pipe?
« Reply #1 on: April 28, 2008 - 08:46:05 PM »
merge pipe should be halfway between the header collectors and mufflers.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 422STROKER
« Reply #2 on: April 28, 2008 - 08:48:31 PM »
Well then I guess for me it can be pretty far back.LOL
So if I put it just past the trans cross member I'm good?
Tom
By tdavist, shot with DSC-P72 at 2008-04-26
Tom
« Reply #3 on: April 28, 2008 - 09:03:50 PM »
i would say so. but btw, please, please get some decent jackstands! those things look they they are set too high, over their limit! I got my 6 ton jack stands for $25 a pair from harbor freight, cheap insurance and go plenty high!
1976 Dodge Warlock
Offline 422STROKER
« Reply #4 on: April 28, 2008 - 09:05:59 PM »
Yeah I've already been scolded a few times.
I thought the 2.5 ton rating was enough. :dunno:  And they are all the way up in that pic.  I'll use the 6 tonners when I do the h-pipe. :2thumbs:
Tom
Tom
Offline wally426ci
    • maryland mopars
« Reply #5 on: April 28, 2008 - 09:07:09 PM »
Tom, i demand you listen to Goody at once!! We're not gonna lose you! remember Phantasm?
NOOOOOO-----> :working:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 422STROKER
« Reply #6 on: April 28, 2008 - 09:09:25 PM »
I got it.  I guess these little ones can hold up the exhaust when I start cutting.
Tom :smilielol: :2thumbs:
Tom
« Reply #7 on: April 28, 2008 - 09:11:17 PM »
yes the 2.5ers will make great exhaust stands  :pullinghair: :wave:
1976 Dodge Warlock
Offline Aussie Challenger
« Reply #8 on: April 29, 2008 - 06:38:43 AM »
  Remember safety first,   :iagree:   You don't have to cut the pipes to install the "H" pipe, just make a reasonable hole that will be covered by the joining pipe. Behind the rear mount should be fine.   :2thumbs:
nivvy
« Reply #9 on: April 30, 2008 - 12:04:49 AM »
there........
Offline 422STROKER
« Reply #10 on: April 30, 2008 - 07:38:19 AM »
Thanks Stroker, thats where I was going to do it.
Tom :2thumbs:
I had seen a bunch located further forward near the crosmember.
Tom
« Reply #11 on: April 30, 2008 - 11:39:41 AM »
As long as the pressure can crossover bfore the muffler you will be fine
Offline 422STROKER
« Reply #12 on: April 30, 2008 - 12:45:02 PM »
Thanks Chryco! :2thumbs:
Tom :burnout:
Tom
Offline nqkjw
« Reply #13 on: May 12, 2008 - 08:58:23 AM »
Every engine will have different exhaust temperatures due to it's build and so the ideal location for the balance pipe will vary.
The correct place for the H crossover can be determined (oldschool backyard method ;))by marking a crayon line along the pipe,start the engine and get up to temp and the point where the crayon melts to is the ideal location for the crossover pipe.
Of course by necessity things like trannys in the way can over ride the best location. ???
Burnouts are cool but Traction is the Action
Offline 422STROKER
« Reply #14 on: May 12, 2008 - 11:55:05 AM »
That is a good tip, Thanks!
Tom
Maybe I'll attack it this weekend, been too nice to take the car out of action.lol
Tom
